Different reading between Rear O2 & Com Port for LC-1
Old Jul 1, 2011 | 08:33 PM
RS200Z's Avatar
I have done the rear O2 hack to allow EvoScan to log my LC-1 wideband via ECU ADC input. However, I notice there is a difference between the data logged via ECU ADC and the COM Port method.
Yes, there is a difference even if I were to log just these 2 parameters alone without the rest which may slow down EvoScan.
My observation shows most of the time, the COM port data is leaner than the ECU ADC's data,
Any idea which would be the more accurate data to base my tuning on?
Edit: I forgot to add that the rear O2 ADC data is matching the figures on my LC-1 gauge.
Old Jul 1, 2011 | 09:19 PM
BakaUnchi's Avatar
use the COM data to get the ADC math right
you will need to change the formula till they match up
Old Jul 2, 2011 | 06:06 AM
RS200Z's Avatar
Are you saying the COM (Serial) port data is more accurate compared to the rear O2 ADC data?
My current formula is x*0.0147+7.35 which is for the default 0-5v (7.35 AFR-22.39 AFR) and it matches the output on my LC-1 guage.
Old Jul 2, 2011 | 07:48 PM
tephra's Avatar
that formula should be correct assuming the defaults in lmprogrammer
what I do to verify the ECU/LC1 is not being affected by ground offsets, is in LMProgrammer set the LC1 to output 0v then log the voltage in the ECU/ADC
then set it to 1v, and relog
2v, log
3v, log
etc
if your logged voltages match the settings you used in LMProgrammer then you have a good connection...
mrfred
Sep 14, 2022 07:08 PM
mrfred
May 1, 2020 10:16 AM
BoMbA_CaJu
Nov 14, 2015 05:41 PM
stokEd
51
Oct 14, 2015 06:44 PM
mrfred
Apr 8, 2008 08:54 PM
