Heat Soak issue. Looking for Air and Coolant temp related fuel trims!
Man this is crazy. I cannot begin say how happy I have been with these injectors (FIC1680)--they fire right up, no problems on long drives or in heavy traffic. No problems doing autoX (hot hot hot sit & wait...hot hot hot sit & wait...) or drag racing with extended idling in staging lanes. Maybe e85 keeps the fuel temperature low enough to not see this issue? Maybe its just a little bit cooler here in MN (mid 80's lately)?
I'd be curious to know as well.
Could be that not all sets of these injectors have this issue, e.g., maybe the wrong o-ring got used for a particular production run. I hope this is the case because these injectors definitely are perfect for many people if they can work right.
There's some up-close pics of mine in my gallery on page 16-18 if anyone is interested in comparing mine to theirs:
http://www.scheides.com/gallery/evoX?page=16
Acording to jens the 2150 and I'd 2000 are on the same body or at least the same style body as the 1680 injector. I am currious how upgrading to the 2000 size injectors could solve the issue here if they are built in the same way or on the same body?
yeah the 1680's are a longer body, but apart from that identical to the 2150's...
maybe the longer body means fuel sits around for longer IN the injector...
shorter body means the fuel is more quickly replaced with cooler fuel...
dunno...
I mean even for me, with a 2.5L, 2150cc/min is going to be too much... UNLESS I run E85, which I probably wont be...
Actually thats probably what I WILL do, tune on E85 to get my latencies worked out, then when I swap back to pump I will just run rich openloop idle... OR dial the pressure right down...
dunno...
Would like to know for sure if FIC is offering an upgrade on these.
The injectors are the same construction but for whatever reason they haven't seen the same issues with the 2000's. I would imagine it's because the sheer size of the injector it closing off helps at idle and there is probably only 1-2 cars using it's full capacity on pump gas.
OBVIOUSLY the design (Not ID OR FIC's fault) is not ideal to begin with...
