Is OBD PIN1 connected to ECU?
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Tephra told me the pin is populated and has sky blue wire in his OBD plug. Unfortunatelly Tephra is too busy to give me more detailed information about this wire.
FSM wiring diagram has no description on PIN1 either.
As I have no X vehicle just the ECU, can anyone do a continuity test of OBD (J1962 Female) connector PIN 1 to Engine control unit? Thanks.
C'mon guys, new features do not come without the help of community.
It is stupidly simple task to track down the wire. It may get us further with stock serial communication, we may get higher logging rates. There is really noone capable of following the wire to either ECU or ETACS?
I have crosschecked FSM, PIN 16 leads to FUSE #5.
Are you saying both PIN 1 and PIN 16 lead to the same ETACS pin?
I am quite confident it is not the case as PIN 1 connects to ground once OEM diagnostic equipment is attached. So there would be short circuit if that is really true.
Koroshiya
21
Nov 18, 2025 12:17 AM
Alchem1st
Mar 15, 2022 08:47 AM
blacktab420
Feb 2, 2016 09:51 AM
