AC controlled by the ecu?
Old Sep 22, 2011 | 09:11 AM
fostytou's Avatar
EvoM Community Team
The plug you are talking about... is it the power / control wire for the AC clutch? ...is it a single wire that plugs into the AC compressor?
When you say "the rad fan does not kick off" do you mean it does not turn on or it does not turn off? That statement is confusing.
Amazing that the dealer couldn't find anything....
Old Sep 22, 2011 | 11:50 AM
JEP's Avatar
JEP
The plug is a 2 wire I believe, and as soon as you plug it up both fans kick on and does not shut off when the car is running. Also the AC still does not work!
Old Sep 22, 2011 | 06:10 PM
crimson red's Avatar
Hello.
(If you can flash the ECU)Did you flash back to the stock ROM and checked whether the AC worked or not?
Originally Posted by JEP
Talked to Chad and nothing was changed in the coolant temp settings, so I'm back to square one. Anybody else got a clue?
Old Sep 23, 2011 | 03:09 PM
JEP's Avatar
JEP
I'm sure I could do that but my tuner is over 500 miles away!
Old Sep 28, 2011 | 05:58 PM
JEP's Avatar
JEP
Guys could I just use a stock ecu from another evo x? Id like to use it at the dealership so they can't blame the ecu flash. Is there anything that would not let it work...
Old Sep 28, 2011 | 11:36 PM
Hiboost's Avatar
I could be wrong but It's possible if the fans are going full tilt that your ECU is bricked but somehow still driving. You can find out rather quickly if you can read the rom with ecuflash and then write it back... if it won't write then the ECU is in a partially failed state and you need to bench the ECU with a battery and some jumper wires as shown here.
https://www.evolutionm.net/forums/ev...-pictures.html
Basically by writing the ECU with a clean ROM again it should take care of fans running as soon as you start up a cold car. One of my sponsors cars was left in this state when it was shipped here and it sure was a surprise when I couldn't communicate to the ECU without benching it.
The sad part is the previous "tooner" said they programmed the car to kick on the fan all the time to keep it cooler... and he drives the car in the winter in Canada. Ugh...
Old Sep 29, 2011 | 05:21 AM
JEP's Avatar
JEP
Well that's sounds interesting^^^ the the problem started when I got a recent tune not knowing my AC fan plug was not connected. I rarely use my AC so I didn't know it was not working untill about a month after the tune. I found the plug not connected so I plugged it up now the fans run All the time on full tilt when the car is running.
Old Sep 29, 2011 | 06:42 AM
ugakirk's Avatar
I say buy a tactrix cable and do what Hiboost said. I'm sure you can even PM him with more details if needed.
That or I would take it to a good A/C shop and see what they can find. There maybe something else still unplugged. Don't trust the dealer..
Old Sep 29, 2011 | 07:45 AM
JEP's Avatar
JEP
Where do I get the ta tactrix cable at?
Old Sep 29, 2011 | 07:57 AM
ugakirk's Avatar
Just google it. You can buy them online. The X needs a different cable than the VIII/IX's though. I think we need the 2.0 version or something. Not real sure on the part number. I think they are usually around 100-150 bucks or something, but then you can change the maps and read the ECU anytime..
Old Sep 30, 2011 | 06:26 AM
EyeDreamt's Avatar
I know on my Ralliart I went and changed a the Stationary Rev Limiter On & Off parameters thinking they'd limit the revs to the setting on there when the car was stationary... It didn't change a damn thing... but my A/C stopped working. Changed them back to the default values and wala, the AC worked again. Not saying this is your issue, but can't hurt to check.
Old Sep 30, 2011 | 07:35 AM
tephra's Avatar
get the op20 from tactrix.com
no you cant plug in another ECU (each ECU is programmed for one car, to reprogram it you need a dealer/mutiii)
Old Sep 30, 2011 | 07:56 AM
JEP's Avatar
JEP
^^^ crap that sucks! I guess I'll just have my oem tune put back in and see what that does.
Old Sep 30, 2011 | 07:59 AM
tephra's Avatar
if you like get your current tune sent to me (either from your tuner or get it from your car) and I will see wtf has gone wrong...
Old Sep 30, 2011 | 03:10 PM
JEP's Avatar
JEP
Thank you Ill try to get Chad to send it to you.
