Idle fuel trim always goes to -12.5%
Just curious what you ended up with. I had my both idle and cruise trims literally sitting +/- 0.38 then a couple days later it was floating between -3% and -4%. while the temperatures were colder...? I've left it as it sits right now since it within +/- 5% but I have a feeling once it gets much colder it will drift of much further.
Has anyone found the table for air temp correction?
I've noticed this too... Mind sharing the actual current MAF scaling for the Primo intake? I have your old and original scaling you shared with me a few weeks ago and my car ended up being no where near close using it so I continued to make changes manually.
With the factory air temperature compensation, the fuel trims will drift with air temperature change, especially with e85. Same thing happens with Evo 8/9. I typically deal with it by altering the injector scaling, but the more proper way to deal with it is to fix the air temperature compensation. We can do that on the 8/9. I can't recall right now if that table is available in ECUFlash for the Evo 10. Its definitely not there for the AP.
ecktt
May 8, 2017 06:18 PM
Green_Bandit
Lancer Engine Management / Tuning Forums
Jun 19, 2013 04:39 PM
EvolutionEst
Aug 22, 2011 09:31 PM
