Copying from Map Tracer in Evoscan 2.7+
Subscribe
Aug 1, 2011 | 01:11 PM
I am trying to copy my AFRs out of Map Tracer using Evoscan 2.7 final (as well as having tried Evoscan 2.8).
But when I select the AFRs from my log, it also selects the cells from my ROM below it, and copy/paste only grabs the values from my ROM.
Any ideas? This is driving me crazy!
Reply 0
Aug 1, 2011 | 03:04 PM
...copy them out of the text version of the log?
Reply 0
Aug 2, 2011 | 02:49 PM
Okay, I just wanted to make sure I couldn't actually select from the chart in Map Tracer. So then that is true? You need to just manually transcribe these values?
Hmm, if this is the case, I'll continue work on a replacement for map tracer I was working on.
Reply 0
Aug 3, 2011 | 07:38 AM
I'm not sure when you would need to do that... describing your situation could help a bit.
If you wanted to you could just make a pivot table in excel of the actual log... no transcription needed.
Reply 0
Sep 6, 2012 | 11:10 AM
I'd need help in that particular subject, I want to Cut/Paste Map tracer information and this seems impossible with evoscan 2.7 and 2.9... It copies the map shown below...
I use an excel map tracer, but I'd want to do it with the evoscan map tracer.
I will try other versions tonight.
Reply 0
Subscribe
