Logging SST fluid temps
Old Sep 11, 2011 | 03:48 PM
project_skyline's Avatar
Is there anyway to log the temperature of the SST fluid in the transmission without putting a sensor into the transmission?
I know the Cobb AP doesn't show anything and evoscan doesn't.
Have any the ECU coders/guru's ran across a way to do this?
I'm guessing if the ECU can see the temps to display the slow down message and enable limp mode there should be a way to log it.
Old Sep 11, 2011 | 05:40 PM
RS200Z's Avatar
Latest EvoScan v2.8 already has the parameter for logging. Look under 2008 JDM/EDM EVO X if you don't find it under USDM EVO X.
Old Sep 11, 2011 | 05:57 PM
Beeble's Avatar
^ what he said
CAN28-0 , x-50 for temp in C
Old Sep 11, 2011 | 07:13 PM
RazorLab's Avatar
Here you go, plus two other goodies I don't think most have yet. I'm sick of sitting on them.
Code:
<DataListItem DataLog="Y" Color="" Display="SST Transmission Temp" LogReference="SST_TM_Temp" RequestID="CAN28-0" Eval="x-50" Unit="C" MetricEval="x-50" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="0" GaugeMax="1000" ChartMin="0" ChartMax="1000" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="Odd Clutch Temp" LogReference="OddClutchTemp" RequestID="CAN33-0" Eval="x/4" Unit="C" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="Even Clutch Temp" LogReference="EvenClutchTemp" RequestID="CAN33-2" Eval="x/4" Unit="C" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
Old Sep 12, 2011 | 09:03 AM
tephra's Avatar
yeh I guess I can probably post up the others as well huh...
https://www.evolutionm.net/forums/ev...arameters.html
Old Sep 12, 2011 | 08:27 PM
Beeble's Avatar
so .... with the SST Temp logging
are we 100% sure it's x-50 as the formula?
i only ask, as some of the mode23 addresses use x-40 as the temp in C (coolant temp, intake air temp)
and my SST shuts itself down at 135 C , which would be 145 C (and make more sense) if the formula was x-40
just thinking out loud...
thoughts?
(and yes i realise this sensor probably isn't the one causing the Slowdown)
Fuego
Mitsubishi TC-SST Discussion
Oct 19, 2016 08:40 AM
LB_Reddy
Evo X How Tos / Installations
Jul 2, 2016 01:40 PM
BeyondLimitsEvo
17
Jun 5, 2015 03:18 PM
RS200Z
Mar 21, 2011 08:47 PM
