MAF Sensor Calibration helper app.
Old Dec 28, 2011 | 02:03 PM
azevox's Avatar
Hi,
Just want to share with the community an app I wrote to help with MAF cal.
The app will do all the tedious work for you and give you numbers to use.
http://www.tunerstools.com/mafcal.php
Hope this help out...
If there's any problems, please post here.
Currently Evoscan and AP logs are supported. If other logs don't work, post here so I can add the support for it.
If you have suggestions for improvement of this one or would like to see new apps, let me know.
Old Mar 15, 2012 | 10:42 AM
fostytou's Avatar
EvoM Community Team
Thanks!
I assume this doesn't eliminate rows where APP (accelerator pedal position) is <13 (aka 0). That might make the program slightly more accurate.
Old Apr 4, 2012 | 06:01 AM
jyamona's Avatar
Originally Posted by fostytou
Thanks!
+1 to this, right?
Old Apr 12, 2012 | 11:04 AM
fostytou's Avatar
EvoM Community Team
Just an FYI if you are using standalone logging these are the 3 items you need to log ('08 USDM)
paramname=MAF_Volts
paramid=0x808F50
databits=16
scalingrpn=x,1024,/,5,*
paramname=LTFT_Current
paramid=0x808C1F
scalingrpn=x,0.1953125,*,25,-
sampgroup=50
paramname=STFT
paramid=0x808898
sampgroup=1
I'm going to try this and eliminate where (TPS < 13% and RPM > 1500). This should keep idle then, although I think STFT might go to 0 when in decel... I just gotta look at the log later and see. I'll also eliminate the cold coolant temps (as instructed).
pr0phet
Site Feedback / Suggestions
Jul 29, 2015 11:30 PM
vmrevo9
Dec 30, 2013 03:23 PM
raza21_84
Mar 29, 2013 11:09 AM
ODUB
Mar 9, 2011 02:59 PM
galvitron
Jun 23, 2007 10:25 AM
