1000cc injector = Retune?
Old May 14, 2012 | 08:00 PM
BaumBizzle's Avatar
Trying to save a few bucks and install my injectors (1000cc) and fuel pump myself before getting retuned. Currently I'm on stock injectors and they're running at 96% duty cycle, so if I were to install the 1000's would they too be running at that same 96% cycle and essentially flood the engine? I've been told all sorts of things like if I install them before tune I'll just run REALLY rich, I've also been told I'd actually run LEAN, another guy told me until I did injector scaling that the ECU would only allow the amount of fuel the stock 565cc's put out to come out of the 1000cc's until I got scaled and retuned….I'm flippin baffled, what can you guys tell me since I know there's a plethora of knowledge here….Thanks for the help fellas
Old May 15, 2012 | 11:54 AM
Golden's Avatar
Injectors are driven by an on/off pulse width. Open / close. It holds them open for x amount of time per intake stroke. That is your IPW value that you can log. If you do not scale your injectors, you will be running the exact same IPW values as the stock injectors needed. Beings the stock injectors are roughly half the size of your 1000cc injectors, you will be squirting twice as much fuel into your engine. That will be a rich condition.
The new injectors will also have different dead times. aka latency
Old May 15, 2012 | 03:01 PM
BaumBizzle's Avatar
So I'd just run really rich then? Could I drive 3hrs to get a tune like that?
Old May 15, 2012 | 03:03 PM
Sidnakit's Avatar
i wouldnt
Old May 16, 2012 | 11:51 AM
Golden's Avatar
Really rich is an understatement.
The question you should be asking is, will my car start? Answer: No
Will your car run? Answer: No
You can push your car the 3 hours, you can have it towed the 3 hours, but the engine won't help you.
Old May 16, 2012 | 12:01 PM
AWDTerror's Avatar
Best quote all month.
Old May 16, 2012 | 12:29 PM
momostallion's Avatar
get to where ever you are going early and install the injectors in the parking lot.
you will be fine to install the fuel pump in advance
Old May 16, 2012 | 02:32 PM
sLowEvX's Avatar
^^^What this guy said
I drove for an hour to get my tune with 1000cc injectors in and it was horrible. Could barely go up hills because once you hit boost it would sputter and stalled when I stopped.
Old May 18, 2012 | 03:11 PM
BaumBizzle's Avatar
Thanks for the help fellas!
Old Oct 31, 2012 | 06:32 PM
racerx43269's Avatar
you have an AP? or a tactrix cable??
Old Oct 31, 2012 | 07:04 PM
PnoiBoiOREO's Avatar
This post actually helped me out too. I will be, in the near future, upgrading the injectors and fuel pump along with installing a fuel pressure regulator and then a tune. I will wait and have the shop install everything along with the tune
Old Nov 2, 2012 | 07:31 PM
tephra's Avatar
injectors take about 15 mins to install.. just do it when you get to the shop..
or have them do it for you, its not hard
Old Nov 2, 2012 | 07:37 PM
xezerax's Avatar
Or if you have ecuflash just modify the three tables and be one your way
Fast_Freddie
Oct 30, 2023 01:56 AM
mrfred
Apr 17, 2015 09:38 AM
Wicked E
E85 / Ethanol
28
May 31, 2011 10:51 AM
Hiboost
36
Jul 16, 2010 07:41 AM
drewdq
Nov 25, 2008 04:55 PM
