Warm motor starting issues
Hello everyone,
When I installed my DW fuel pump and ID 1000cc injectors I started getting hard starts only when the motor is warm. for example, when it's cold or when it's hot (turned off for less than 5 minutes) it starts right up. When it sits for 20+ min it takes 5-10 cranks to start up with me priming the fuel pump and giving gas.
I had the crank enrichment tuned to buschur's ID 1000 specs and that seemed to work for about 3 weeks, but now the issue is back again.
Any ideas??
leaky injectors wouldn't make sense because I would assume that would prolong the cold start as well.
I know the fuel pump is good because my tuner checked it, and checked fuel pressure upon start up, all was well.
Any ideas??
pennies_hatchie
68
Mar 5, 2023 08:02 AM
RS200Z
Jul 20, 2011 01:56 AM
