Re-tune for LICP?
No, most are the same size as stock (2.5"), even if you got a 2.75" LICP it won't change that much. The stock one is actually pretty descent and you won't see a big difference going to a different one (except it'll look better).
~Chris@MooreAutomotive
Tuner/Master Technician
Do some logging before and after to understand if anything changed. If something is thrown out of range then re-tune. But as Moore Auto said, aftermarket LICPs for the Evo X are known to offer zero gains over stock so re-tune probably isn't going to be necessary. That being the case, the LICP isn't necessary either unless it's for show.
GSRSTIKILR
Jan 21, 2014 03:54 AM
cnoevo8
Jul 5, 2011 11:27 AM
