Sponsored by:
Sponsored by: CARiD
CBE, tune, what next?
Old Oct 18, 2010 | 07:44 AM
Laz's Avatar
Laz
Question CBE, tune, what next?
My Evo X GSR has CBE, air filter, and tune. +53 whp over stock right now.
What's the next best bang for your buck mod wise? I wanna keep it less than $1500 preferably (including the re-tune). From what I've searched on here, LICP and downpipe are sorta useless on Evo X unless you're going past 400 whp (which I'm not lol).
Any comments or opinions are appreciated. Thanks
Old Oct 18, 2010 | 09:03 AM
OBP's Avatar
OBP
UICP and Intercooler upgrade would be my next step.
Old Oct 18, 2010 | 09:52 AM
iEvoX's Avatar
I would get a test pipe since there's a lot of restriction there.
Old Oct 18, 2010 | 09:59 AM
ugakirk's Avatar
+1 on getting a test pipe. I would get a test pipe and an UICP and maybe an intercooler depending on the money.
Old Oct 18, 2010 | 10:16 AM
Laz's Avatar
Laz
What benefit is the test pipe? I've heard they throw CELs and/or don't pass inspection. Is this true? What kind of gains can I get from the test pipe?
What kind of gains can I expect out of UICP and FMIC?
Old Oct 18, 2010 | 10:52 AM
ugakirk's Avatar
A test pipe will prolly get around 15whp. You can get a TP with a CEL fix so it won't come on. A test pipe just replaces the stock cat. If you have emission tests, a TP won't be your best bet. Maybe a high flow cat.
A UICP and an intercooler will prolly get around 20ish too after a tune.
Old Oct 18, 2010 | 10:56 AM
BAMFevo's Avatar
Test pipe eliminates your stock cat. I just got mine installed on Friday. Made my car slightly louder. You can get an adaptor for your O2 bung which wont throw a CEL. My mechanic told me that as long as your check engine light isnt on, then you'll pass inspection. Gains were decent. Prolly 12-15.
As for your next mod...down pipe? I dont remember seeing if you had that on your mods list or not?? Otherwise intercooler and hardpiping.
Good luck with everything.
Old Oct 18, 2010 | 11:01 AM
Laz's Avatar
Laz
Yeah NC has emissions law so I'm worried about the test pipe. But if that's true about "no CEL then pass inspection" then I should be good. Thanks for info guys!
Old Oct 18, 2010 | 11:15 AM
Laz's Avatar
Laz
Also, would I be able to install a FMIC and UICP before I get it re-tuned? I'd like to install the parts myself but I know nothing about tuning.
Old Oct 18, 2010 | 11:44 AM
iEvoX's Avatar
Honestly I don't think you'll need a retune for just a FMIC and UICP. idk someone else could chime in but I think you'll be fine. I would get retuned if you put a test pipe since I know that will free up the exhaust quite a bit. Only thing is, if you dont get retuned you wont know how much power you picked up
Old Oct 18, 2010 | 03:03 PM
BAMFevo's Avatar
Well its just if you know if they'll take a mirror and look under the car. In WI they dont, but I couldn't tell ya for NC.
Old Oct 18, 2010 | 08:02 PM
ugakirk's Avatar
You don't need a retune with a UICP and intercooler i wouldnt think. Like the OP said tho you would want one with a test pipe bc it will prolly make your boost spike higher with the exhaust freed up. If you don't want a test pipe I would atleast go with a high flow cat.
Old Oct 18, 2010 | 08:11 PM
EvoX-11's Avatar
Why is downpipe useless?
AMS claims that their downpipe adds 15whp
http://www.amsperformance.com/cart/A...-Downpipe.html
Old Oct 18, 2010 | 08:19 PM
iEvoX's Avatar
Thats an O2 downpipe which does add hp. The stock downpipe flows very well but the o2 housing is the restriction. downpipes=bad... o2downpipes=good
https://www.evolutionm.net/forums/ev...zero-gain.html
Old Oct 18, 2010 | 09:49 PM
evokerfes's Avatar
Change O2 Downpipe when you change your turbo. I don't consider it worth it without a turbo upgrade. In addition, if you get a clutch job, the O2 downpipe has to be removed in order to change the clutch. As others said, get a UICP and an Intercooler. And If you don't have one already, get a wideband and start logging. Although others said you don't need a re-tune, it's still a good idea to start logging so you yourself knows that your car is safe and you have a peace of mind. In addition, you could get a test pipe.
