Virtual Dyno help
Virtual Dyno help
So iam in logging mode 23whihc has been allowed on my tune . Iam using evo scan 2.9
I do the logging then switch over to virtual dyno and get ;
E101: Not all columns needed for calculations. Required columns are : Time , RPM, Throttle Position
what am i doing wrong
its all been deleted. This stupid program has wiped it
its even wiped word docs aswell. FFS
Recovered 1 Rom using file recovery software. But i need the orig rom
I still cant understand why this all happend.
The reason that you got the error in the first place is that one of the columns in the csv file is labelled incorrectly. Would have taken a few minutes on google to sus this out.
Very strange that uninstalling one program deleted info in other folders. I've uninstalled virtual a couple of times with no adverse effects
Note:- Always back up stuff you don't want to lose, esp base or personally tuned ROM's.
Good luck with recovering your stuff
there is no way it deleted word documents and your roms unless you saved your roms in the same folder you installed Virtual Dyno to. If you did that then you need a lesson on where to save your data (Roms and word docs).
It was on my desktop and so was all the word docs and roms. Seems like it wiped everything on the desktop. Not to worry iv found all my roms saved on another computer.
To anyone else reading this. Make sure Virtualdyno is in a separate folder and only have a shotcut on ur desktop.
It defaults to the folder it should install to ... Im not sure how you got this to happen using the installer unless you actually installed it to the desktop which is a little crazy.
dragged and dropped from your usb stick ... elaborate ... if this is a problem with VD Ill fix it ... Im trying to understand the scenario that got rid of your files. I highly doubt its a problem with VD BUT ... I treat everything with the same sense of curiosity and devotion to quality.
Iam determined to get this to work.
So can anyone explain whay iam getting this "E101: Not all columns needed for calculations. Required columns are : Time , RPM, Throttle Position"
Tried google but got nothing useful
