Recommend turbo for 400/400 on stock block plus pump gas
Old Jan 14, 2013 | 05:22 PM
Thatotherguy's Avatar
I know the fp green gets me this, but is there a more cost effective alternative?
Old Jan 14, 2013 | 06:04 PM
Kracka's Avatar
I needed the MAP EF2.5 to get 400 WTQ; my current is 425 WHP/400 WTQ on pump gas, stock block, and stock cams. An EF2 or Green will be able to hit 400+ WHP on pump, but will require cams to get 400+ WTQ.
Old Jan 14, 2013 | 06:54 PM
Spazpilot's Avatar
What Kracka said. If 400 is all your looking for Green, EF2 or the 2.5. I'm also keeping an eye on the new Mitsubishi turbo. Seems to basically be a JB Green.
Old Jan 16, 2013 | 11:10 AM
Pbayr0lla321's Avatar
Cost effective = Map EF 2.5 or 3
I am personally going with the Map EF3 for my power goals. Stock block and cams.
Old Jan 16, 2013 | 05:28 PM
DocBoz's Avatar
curious as to what your power goals are? i know the ef3 will max out your block without cams, lookng for a higher rev limit?
Old Jan 17, 2013 | 09:45 AM
fostytou's Avatar
EvoM Community Team
Depending on your mod situation and tuner the BBX Lite should be able to get you close if not there. The tq number is going to be the harder part - but you should remember that it drops off rather quickly on turbos that are being run to high PSI.
You should also do a lot of comparisons of actual dynos because many can spike above 400 with a boost curve that's too tight and immediately drop 20-30tq as the spike settles. These stock framers aren't cheap and all behave differently on different cars.
Better yet - call a couple of shops selling stock frame turbos and ask some well informed questions. Getting the information from the horses mouth is great with reliable shops.
Old Jan 17, 2013 | 10:01 AM
The car is currently making 321/321 on PRS's mustang dyno on the stock turbo. Off the bat with fuel upgrades and tune I would like to safely make low 400's and keep the torque around 350 safely. Why the EF3? Because it leaves room for improvement. If/when I decide to do cams, I can.. but I can still use it as safe, streetable "bolt-on" solution.
Old Jan 17, 2013 | 02:12 PM
MisterHappy's Avatar
If you don't have to have pump gas, and have E-85 near you. Just bolt-ons, injectors, and a fuel pump and put you in the 400s.
Old Jan 17, 2013 | 02:39 PM
JohnBradley's Avatar
HTA Green and O2 dump
Aaron
Old Jan 18, 2013 | 08:46 PM
If you want 8k max rev do you need to get piston and rods, ef2.5 still pushingout power at that rpm?
Old Jan 18, 2013 | 09:00 PM
Sharkbite2000's Avatar
I think I made 400awhp on stock turbo a few years ago.
Old Jan 19, 2013 | 10:21 AM
racerx43269's Avatar
not true....
I have CAMS and VALVETRAIN..... on a stock bottom end... and CAN push to 8500... while i choose NOT TO... doesnt mean it cant be done..
Old Jan 19, 2013 | 10:32 AM
here is the deal... you want to be on pump gas... and want to make 400 AWHP.... this is what you need
its plain and simple.. fp green and ef2 WILL get you to 400.. with little room to grow... an FP red, or ef3 will get you beyond that... it is really up to you... I personally chose an fp green.. it was like 1100 with all the options to get my stock turbo rebuilt. it worked for my budget., but it might not for you...
despite what all of us say online.. you really need to sit down and think about what you want to do with the car... because for example.. changing cams... changes entirely how the car drives ( i have my write up that i will be posting shortly.. after a month of having my cams in.. and all the different things tha i ahve notices.
changing a turbo away from the stock frame turbo will also change how the car drives.. i.e. boost lag... boost curve... how hard the boost hits... seriously do some more research adn dont just post on the forum.. watch videos look at dyno charts and see where the boost is and how it feels... see if there is anyone that lives near you and see if they will give you a ride in their car with that setup.. CALL the shops.. and talk to them.. not just one.. 5 of them.. see how they feel about it.. it isnt about brand or name.. is it about performance in what you want your car to do.. for example.. if you auto x.. dont bother going to a map turbo or a green.. they wont spool in time.. ( just from personal experience ) if you drag race.. an ef3 or fp red or black..
most of all.. good luck..
Old Jan 19, 2013 | 10:36 AM
Old Jan 21, 2013 | 03:37 PM
chaz01gt's Avatar
FP Green works nicely...my buddy is at like 400 hp on stock turbo
tobz
Feb 16, 2011 06:46 AM
Elevent
11
Feb 22, 2010 05:32 AM
EvoX6436
Jan 25, 2010 10:33 PM
blackevo4
Aug 16, 2009 09:57 AM
evo400
Apr 13, 2008 02:15 PM
