Am I running lean 32 mpg
Old Mar 15, 2013 | 08:46 PM
Thatotherguy's Avatar
I'm getting 32 mpg at 60 mph, is this normal for the Evo x
Old Mar 15, 2013 | 08:48 PM
AJsGenerX's Avatar
Definitely Lean. You need to datalog and use a wideband to find out how lean you are running. WOT is where you need to log.
Old Mar 15, 2013 | 09:44 PM
So I'm guessing its possible to blow my motor just going 60 mph light on throttle
Old Mar 15, 2013 | 10:12 PM
JohnBradley's Avatar
No...not cruising. Am I getting this right you are worried about good mileage?
Old Mar 16, 2013 | 05:54 AM
FastAttack's Avatar
I'd be happy if I got that gas mileage at cruise lol
Old Mar 16, 2013 | 07:36 PM
Yep, getting good gas Mileage in evo don't belong in the same sentence. It turns out it was just that section of road.
Old Mar 21, 2013 | 01:18 PM
Octane Blue's Avatar
Are you REALLY getting 32 or is that just what your display is showing.. If injectors aren't properly scaled in properly you can get miscalculations of MPGs. I myself had experienced this. If you REALLY are running that lean, you'd be throwing system too lean codes too I'm sure.
Old Mar 21, 2013 | 01:59 PM
Ev0ikon's Avatar
It must have been a downhill section of the road. :}
Old Mar 22, 2013 | 06:21 AM
rrkpitt15's Avatar
Your tune does not effect your cruising gas mileage (in most cases). Running in closed loop, which is what you do when you are cruising unless you are cruising at a fast speed, the front O2 sensor reads the AFR and the ECU tries to adjust the fueling to reach 14.7 AFR. Unless you are not running in closed loop or maybe have a bad front O2 sensor, you should be fine.
Do you have a wideband? This should be the evo's first mod.
Old Mar 23, 2013 | 07:27 PM
beetle_orange's Avatar
Gts?
Old Mar 27, 2013 | 09:18 AM
jlldetroit's Avatar
32 Mpg I wish
Rosica
39
Jun 14, 2017 04:04 PM
IamMattMoses
Jan 1, 2015 05:40 PM
lionkoala74
18
May 11, 2012 01:15 PM
blewbyu
Sep 26, 2011 03:57 PM
DMP
Jun 28, 2011 01:42 PM
