ECU Harness
Old May 19, 2013 | 12:49 AM
anasyakoub's Avatar
ECU Harness
Hi,
I'm planing to install a Haltech sport 1000 ECU for my EVO X,
and I what to do a custom harness for it, its a Y harness so it will be connected to both OEM ECU and Haltech, without cutting OEM harness like the attached sketch,
it will be like extension then I will direct some wires to the new ECU
So where to get the ECU male and female connectors ???
Or even an extension Harness ??
I have searched a lot online without any results
Old May 19, 2013 | 12:59 PM
Subi.convert's Avatar
I bought a HKS VPRO harness to do the same thing since its a piggyback style setup. You might look into doing the same or buy an old harness to cannibalize
Old May 19, 2013 | 01:17 PM
anasyakoub's Avatar
Which ECU are you using ?
Old May 19, 2013 | 07:17 PM
Not sure yet. I was going to use the HKS VPRO but I havent found a tuner yet since only HKS prowriter shops can tune it. I was thinking id see if I could do what you were thinking of except with a motec 800. If you can figure out how to do it with a Haltec then I might go that route.
Old May 19, 2013 | 09:58 PM
anasyakoub's Avatar
if you going with MOTEC M800 you don't need the harness cuz Motec has plug and play ECU,
For the Haltech I know someone on going on his project, so just a few days and we can get some results,
Haltech has the same functions as Motec with less than half price but not PNP
I'm going to check about HKS F-CON
Old May 20, 2013 | 05:59 AM
No motec plug and play for SST equipped cars.
JRally
May 22, 2016 04:22 PM
adolfo415
Sep 28, 2015 10:43 AM
AWD Motorsports
AWD Motorsports - Florida
37
Mar 21, 2012 07:29 PM
acssa
Feb 3, 2012 09:11 AM
AWD Motorsports
Jun 17, 2009 05:29 PM
