Cobb accessport obdll connector broken, help
Old Mar 1, 2014 | 02:38 PM
milab21's Avatar
I just got a cobb accessport that I bought off another member on here, and with out knowing, the back of the accessport where the obdll connector would clip onto is broken, right where the clip snaps onto. Can I still flash my car? Is it safe?
Old Mar 1, 2014 | 05:47 PM
blusubman's Avatar
as long as the pins are not bent deformed or look as if they were bent back into place you technically should be good. just make sure its fully seated when your flashing if it falls out during a flash then your going to have a bad time. maybe put a piece of tap to hold connector in place. if you feel uncomfortable with they way it is, try getting your money back.
Old Mar 2, 2014 | 01:51 PM
milab21's Avatar
Thanks, I gave it a shot, worked fine.. I'll probably just upgrade it to the v3 soon.
milab21
For Sale - Wheels / Tires
Nov 23, 2015 01:50 PM
milab21
10
Nov 19, 2015 03:38 PM
milab21
Sep 27, 2015 06:36 AM
Champion3
Apr 25, 2014 03:12 PM
Sykes
Nov 23, 2013 06:00 PM
