Evoscan Wont Connect to ECU
Old Oct 24, 2013 | 02:40 PM
Sykes's Avatar
I recently just bought an Evoscan for my 8. v2.9, 1.3DA cable
had it working the first day i got it but now it wont connect to my ECU.
It just sit there and cycle through these lines while trying to connect,
"Awaiting Init Response"
"Attempt baudrate 62500"
"Auto try in 1 second"
"Initialize vehicle ECU....retry #"
"Timeout, turn the car on/off"
(might have messed the order up but you get my point)
I have tried starting evoscan with the key in various positions and still get the same error.
Any ideas on what i could be doing wrong? Any help would be greatly appreciated
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Oct 26, 2013 | 08:39 AM
Sykes's Avatar
bump
Old Nov 7, 2013 | 01:22 AM
Sykes's Avatar
still havent solved this issue any help would be greatly appreciated
Old Nov 7, 2013 | 04:35 AM
todd6027's Avatar
try 15625 as the baud rate in evoscan
Old Nov 11, 2013 | 04:26 PM
1hotevo9's Avatar
i was having the same problem.
Try driving the car first and charge the battery, i know i sounds weird but if the battery voltage is low it wont flash.
Old Nov 11, 2013 | 05:19 PM
lancerrally45's Avatar
All your drivers install correctly? I just went through an issue where they didnt want to install right. Figured it out finally. Open up your device manager and see if you have any showing they arnt installed, while being connected to the car.
Old Nov 20, 2013 | 01:52 PM
littlewack's Avatar
mine will do the same thing if my battery is below or near 12 volts. I usually start the car for a few min, turn it off and turn on the ignition and it will connect.
Old Nov 21, 2013 | 03:51 AM
Sykes's Avatar
are you talking about drives on my laptop? i haven't connected my laptop to it yet. This is just connecting the tablet (the in car one that comes with it) to my ECU.
Old Nov 23, 2013 | 06:00 PM
Sykes's Avatar
got evoscan working this morning. turns out it is my battery. will look to replacing it. now just gotta work out which setting turns on the important stuff
milab21
For Sale - Wheels / Tires
Nov 23, 2015 01:50 PM
turbotaloon95
14
Mar 5, 2014 11:47 AM
milab21
Mar 2, 2014 01:51 PM
labshazam
Jan 31, 2014 09:59 PM
1sxyrxy
Jan 22, 2014 07:30 AM
