Evo X Upgrades
Old Mar 15, 2014 | 12:54 PM
Kidkuda35's Avatar
Evo X Upgrades
Is it possible to reach at least 400whp on stock engine? If so what would I need to do to reach my goal? Thanks for your inputs ahead of time
Old Mar 15, 2014 | 01:20 PM
evostanman's Avatar
With running E-85 you can hit 390-400 whp on the stock turbo. Otherwise you are limited to 350ish on 91 and the stock turbo.
Check this link
http://www.socalevo.net/threads/222047-350hp-400hp-goal
Old Mar 19, 2014 | 12:28 AM
Treyzian's Avatar
Depends what you call a stock engine. Also depends on what dyno.
VD is completely different from a true MD.
Old Mar 27, 2014 | 09:27 AM
dbreeze223's Avatar
Adding the cams will probably hold you back as the installation is the hardest of the parts. But it still really isn't that hard
Old Mar 27, 2014 | 09:36 AM
f-dub's Avatar
Full bolt ons and a FP green or MHI TF06-18K turbo will get you to 400whp on a Dynojet depending on the tuner.
Old Mar 27, 2014 | 04:22 PM
import111's Avatar
+1
Or any similar flowing turbo...EF2.5, BBX full, ect.
Old Apr 22, 2014 | 12:46 PM
galownia's Avatar
Originally Posted by import111
+1
+2
Kracka did it on an ef2 and an ef2.5 on cobb dyno. He has ALL the bolt ons, however, and Cobb can read a tad high, from what I understand.
https://www.evolutionm.net/forums/ev...ing-plano.html
Old Apr 26, 2014 | 02:35 PM
apagan01's Avatar
You can get 450 reliably. . 400 is a better number the engine will last with no issues.
I ran at this power for over 2 years
Old Apr 29, 2014 | 05:46 PM
sik_z33's Avatar
Full bolt ons + e85 is all it takes, Just picked up my 2011 WW gsr thats all im doing.
chansdaman
Jan 10, 2016 05:31 PM
bangpe13
Apr 5, 2015 09:35 PM
mr2rr
12
Feb 13, 2015 08:43 AM
boostedrb
Mar 10, 2014 08:19 PM
