EvoScan AFR logging with RAX help plz.
Old Apr 17, 2014 | 12:28 PM
erikm-x's Avatar
i have a 2008 GSR, and currently getting E-tuned. I have a netbook set up with my tactrix cable and a aem uego wideband. The problem is that when i try to log using RAX everything works except the AFR. It will freeze at 15.1 or not show anything at all. It will not show the wideband not connected error at the bottom, it will just not log.
It was working fine for like 8 months up until now. I have evoscan 2.900023 and using a serial port with a serial to usb wire for the uego. anyone has any idea maybe I didnt set something right? I make sure and pick the right port for the uego. I'm stomped. Any help with this issue would be greatly appriciate.
Old Apr 18, 2014 | 10:49 AM
erikm-x's Avatar
bump anyone?
Old Apr 20, 2014 | 12:29 AM
Raptor58559's Avatar
Try using EvoScan 2.8.
I don't use the FastLogging from RAX but a few other things.
2.9 was sometimes tricky when logging or reading CEL codes.
Michael
richardjh
May 24, 2026 12:49 AM
richardjh
Nov 6, 2024 04:41 AM
Rasperin
Mar 18, 2018 11:00 AM
Dimmoun
Apr 19, 2016 12:20 AM
babaz7
Mar 10, 2016 07:17 PM
