Zeitronix Analog Output Serial to USB
Old Jul 29, 2014 | 07:30 PM
kiddsm95's Avatar
I need input from other Zeitronix users.
I'm trying to output my WBO2 values to the ZDL software. I've abondoned Evoscan because I do not have Mode 23 enabled (keeping warranty intact).
Using Zeitronix logging software, I'm unable to read any AFR data thru my Serial to USB cable. The installation instructions state the white wire is for Analog Output. However unlike the instructions for the AEM UEGO, Zeitronix doesn't state which pin on the DB9 connector the white wire should attach to.
Therefore using the instructions from AEM, I installed as follows:
Zeitronix white wire - DB9 Pin #2.
Chassis ground wire - DB9 Pin #5.
Is this correct?
Using this method I am unable to read any data in ZDL. The Serial to USB cable is a Dynex-UBDB9. Based on research here on EvoM & other forums this cable was highly praised for datalogging.
Any input is appreciated.
Reference:
http://www.zeitronix.com/installatio...structions.pdf
http://www.jegs.com/installationinst...17-30-2310.pdf
mrfred
May 1, 2020 10:16 AM
CO_VR4
Dec 22, 2016 05:57 PM
needsboost
Jul 11, 2013 11:09 AM
vwjeff
Mar 8, 2013 06:42 PM
Extas
Apr 25, 2010 06:36 PM
