P0016 code
Old Feb 19, 2015 | 11:11 AM
mdanielswv18's Avatar
P0016 code
Just finished installing an FP Green turbo, DW300 fuel pump, ID1300 injectors, a MAP tubular manifold, AMS downpipe, Kelford 214a cams and an updated timing chain. I am running a base map from Motion Lab. Initial startup sounds fine, broke in the cams at 2k for 20 minutes shut the car down and restarted. When I restarted I got a P0016 code for crank position sensor. I have triple checked my timing and it seems spot on. I took my time setting my valve lash...was down 2 weeks waiting on proper buckets. I dont see any cracks on my cam gears. When logging mivec settings at idle exhaust is on point but intake target is 10 and it is reading -5. At around 2k rpms exhaust is still on point but intake setpoint is 13 reading 8.975. Does the computer need some sort of an update after the timing chain install even though I had no cel before the install? Does this sound like it could just be air in the Mivec solenoids?
Old Feb 19, 2015 | 06:35 PM
Here are some pics of the timing I took after tearing it back down again tonight.
manofdafam
Jan 30, 2015 04:02 PM
geoxrge_gsr
Jul 1, 2013 09:14 PM
evokid4life
Mar 25, 2013 10:13 PM
RonsEvoTwin
Feb 24, 2011 05:33 AM
Stormtrooper
Jan 3, 2010 07:28 PM
