Car is stuck in Program Mode?
Old Apr 13, 2015 | 09:16 AM
mikes3kgt's Avatar
I just got my car back from Evolution Dynamics in Lewisville, Texas from a complete motor rebuild. Long story short my 4th Cylinder took a dump and compression was reading ~50psi. So decided to do a rebuild. Car is now built. I put about 170 miles on the car with nothing over 12psi for break in. I was making a left under a bridge to hop on the highway and car shuts off. Pulled over immediately to take a look and fans are stuck ON, ALL warning lights are on dash. Engine overheated, AWD Service needed, Ect. I called tuner ASAP and he was on his way. I did some research and found that the car is stuck in Program Mode. Tuner gets to where I am located and hooks up his laptop to the car only to find that the laptop can't connect to the Evo now? Has anyone had this issue? Any ideas? Thanks a lot for reading and any input!
Old Apr 13, 2015 | 10:38 PM
franzcars's Avatar
Checkt he ECM fuses in the engine bay, i read someone had the same issue as you, car randomly died while driving and he ended up popping a fuse
jayson2k2
Jun 10, 2023 03:01 AM
REDGTS
Lancer Tranny/Drivetrain Tech
Jul 1, 2011 09:32 PM
Jooyoung99
Jun 18, 2010 02:58 PM
RevMoto
Feb 4, 2009 03:43 PM
RevMoto
Nov 24, 2008 09:37 PM
