My Mechanic Made Me Paranoid
Old Jun 16, 2015 | 08:10 AM
GotKT?'s Avatar
So I just got my 2011 X-MR back from the shop after a costly exhaust leak from the exhaust manifold coming loose from the block. Prior to my last track day, where the damage was done, I got a Grimspeed 3-port and a tune. Only other mod is a Walbro 255 fuel pump that came with my surge tank. My tuner set me up with a 25 PSI tune that got 295 WHP on a Dynojet. Does that seem reasonable? Is a 25 PSI tune reasonable or am I asking for trouble?
So my mechanic (i.e., shop owner) is concerned that my boost is too much. One of his techs, who seems to know more about boosted 4 bangers, thinks my problem may have been overcooking the exhaust manifold due to high AFR. Did a couple of 3rd gear pulls and boost was spot on at 25 and AFR was 11isth. I have noticed that if I go full throttle in SST-normal, boost goes to 27 for a moment, before settling at 25.
I’ve attached the tune and would appreciate any feedback.
File Type: zip
Old Jun 16, 2015 | 08:16 AM
ddlopresti's Avatar
25psi and 11s afr is totally normal and reasonable for bolt ons. I've been running 28.5 lbs on pump fuel for over a year with no issues and 30 on e85 and I have a stock motor as well. I would suspect that your mechanic doesn't know much about evos, we run much more boost than most other FI applications.
LSD Motorsports
West Region
17
May 18, 2017 03:23 PM
Derek888
Feb 26, 2006 02:31 AM
fuzzychi
Dec 9, 2005 01:58 AM
dimo
Apr 7, 2004 03:22 PM
