Power not like should be - help appreciated :)
First my issue - Evo X with GTX3076 at 25psi and it seems like it is slower than with the stock turbo.
The whole story.
This is the first Evo X which I tune.
Been a bit of a learning curve.
Last year I was running the stock turbo/cams/maf/injectors and it worked fine.
This winter I installed ETS GTX3076 turbokit , FIC2150, 3.5" MAF and GSC S2 cams
It took quite a while to figure out injector scaling and some other driveability stuff.
So on to power tuning ignition,mivec and AFR on 25psi running around 11ish AFR's and about 6 degrees timing after spoolup.
But it feels like it is slower than before with the stock turbo.
I have done a pressure leakage test
checked the Blow off valve "stock metal one"
Thought at one point that the throttle plate was'nt opening all the way but I cant really verify that , eg cant find a way to log that in evoscan.
If anyone has some ideas I would be really grateful
Gudmundur
The whole story.
Gudmundur
tuning from my understanding is quite diffrent from the evo 8 the a X with the mivec. maybe its just as simple as poor tuning on your part? Not saying it is but just a suggestion. as if all else the same it should be faster..
I agree that it could very well be bad tuning.
I have though seen mivec maps from other Evo X running similar turbos, and have been using those maps but that didnt change any thing
JHS VIII
Jan 20, 2012 01:42 PM
Dale
Jun 10, 2010 11:30 AM
spoolinEVO8
14
Feb 17, 2007 12:40 PM
on3ofak1nd
10
Dec 17, 2002 06:48 AM
