Connecting Wideband to Rear O2 Harness
Old Nov 14, 2015 | 05:21 AM
fi8tzer0's Avatar
I followed the how to on connecting a wideband to the rear O2 for ECU logging. He uses a yellow wire from the harness to connect to the ECU. My harness doesn't have a yellow wire, apparently they are not all the same. The sensor has been removed, and disabled in the ECU. I know I'm in the right spot because I removed the sensor myself and un-clipped the connection. My car is a 2012 MR. Does anyone know what color wire I need to use by chance?
Old Nov 14, 2015 | 05:17 PM
stocker77's Avatar
I've been searching quite a bit and came across some other posts showing that the yellow wire change to green sometime in 2012 I believe. There are other posts confirming 2013's are green on another forum.
Old Nov 14, 2015 | 05:25 PM
fi8tzer0's Avatar
Awesome. That helps a lot. Thank you sir.
Old Nov 23, 2015 | 11:15 PM
bobssecrtsn's Avatar
no problem
rydogg008
Jan 10, 2015 10:15 PM
TurboTJ
Apr 28, 2013 11:43 PM
Chereck04
39
Jan 11, 2011 01:00 PM
justastockevo
Sep 13, 2010 01:51 AM
