Sonata Turbo - Theta engine
Old May 3, 2018 | 05:53 AM
ecuspec's Avatar
what do you think about modification - engine looks pretty similar - smaller turbo and cooler and Siemens ecu.
Old Jun 6, 2018 | 10:25 AM
strykr's Avatar
Veteran: Canadian Forces
Engine is not similar enough, Trans mounting won't work, the trans bolt pattern is different. I had a GC before which uses the same Theta block so I know. I already looked at this year's ago, the 4B11 and Theta can't be swapped. There are similarities between the two blocks but not in a way they can be used back and forth.
Old Jun 7, 2018 | 03:38 AM
Norbert Bercik's Avatar
ECU will go to Italy for protocol build cause Dimsport doesnt have yet this duble Tricore in database after that i will write Dyno info
EVOX_SPEED3
19
Apr 2, 2010 02:22 PM
Jehuty
20
Feb 26, 2008 04:15 PM
