First time Tuner !!!
Old Jan 19, 2020 | 12:40 AM
Evo4RN's Avatar
Hey evo guys, I live in cali and the smog laws are making it hard for car lovers to have fun. I want to learn how to reinstall and download software for tuning. What system is recommended? can I use MAC book air? what should i know before i start to tune the car? any tips will be greatly appreciated!!!
Old Jan 19, 2020 | 03:36 AM
splattj's Avatar
Welcome!
I'll link a bunch of really good resources below. There are a couple outstanding members here who will be able to help you with specific questions along the way so don't be shy posting!
This is pretty much the definitive guide to tuning the Evo X ECU:
http://thefrost.net/randomfiles/tuni...GUIDE_V2-0.pdf
You're going to need one of these:
https://stmtuned.com/collections/tac...x-openport-2-0
You'll need this to tune:
https://www.tactrix.com/index.php?op...d=36&Itemid=58
And this to log:
https://evoscan.com/
And here's a 16-part video primer on ECU Flash
https://www.youtube.com/channel/UCFJ...EXIDaNQ/videos
Old Jan 19, 2020 | 04:00 AM
Evo4RN's Avatar
Thanks man, so i tried posting on the evo scan website it said the page was closed due to scam mail. I am curious if this will work with my mac book air? i have watch alot of videos and i havnt seen one with a macbook? i also was wondering if i due flash my car with a tune can i reflash back to the original stock tune so i can pass california smog when my time is up?
Old Jan 19, 2020 | 07:14 AM
splattj's Avatar
ECUflash is Windows only so you'll need to run Parallels, Crossover, VirtualBox *FREE!, or Fusion or just buy a $200 windows laptop for tuning.
Old Jan 19, 2020 | 11:58 AM
Warhawker's Avatar
You also need to log AFR.
My laptop had only 1 usb, so I got a 1 to 2 splitter for data.
this one works, I use it myself.
https://www.amazon.com/gp/product/B071JTSMVQ/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B071JTSMVQ/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
And this cable allowed me to convert my serial to USB.
https://www.amazon.com/gp/product/B00425S1H8/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00425S1H8/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
If you have an AEM AFR gauge already, get this output cable if you don't already have one.
https://www.amazon.com/gp/product/B00595QJ4W/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00595QJ4W/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
This allowed me to easily wire in from my AEM gauge output.
https://www.maperformance.com/produc...tm-evoscan-log
And beep bop boop, you're ready to go.
Old Jan 19, 2020 | 03:23 PM
Evo4RN's Avatar
Awesome thanks guys super helpful. So if I learn how to do this, would I be able to flash and reflash my car as many times as I want? I really only need two flashes. My stock flash to pass smog and my tuned flash to have fun? So this will be done every two years in my case ?
Old Jan 19, 2020 | 05:15 PM
Warhawker's Avatar
Yep should work fine. I've flashed my car probably 9 times in the past 2 weeks.
Just be really sure your battery voltage is good, and your connections are tight.
If your battery is weak, hook a charger to it. The cooling fan will come on during the reflash, and electric cooling fans are a significant load on the electrical system. I'm usually at 11.3v during a flash with the fan running.
Old Jan 23, 2020 | 04:57 AM
splattj's Avatar
Really good advice. Loosing too much voltage mid-write can brick your ECU. Jumper packs work well too if you don't have access to a higher-amp plug in charger.
Old Jan 23, 2020 | 10:58 AM
bmxhotsauce's Avatar
I got the below stuff and it works great for. EVO Scan, ECU flash, Team viewer and Mega log viewer , and AF logging.
https://www.bestbuy.com/site/hp-stre...?skuId=6356082
https://www.amazon.com/Innovate-Motorsports-3892-Wideband-Oxygen/dp/B013UG0ERE/ref=sr_1_1?keywords=innovate+boost+and+af+gauge&qid=1579805726&sr=8-1 https://www.amazon.com/Innovate-Motorsports-3892-Wideband-Oxygen/dp/B013UG0ERE/ref=sr_1_1?keywords=innovate+boost+and+af+gauge&qid=1579805726&sr=8-1
https://www.amazon.com/Sewell-Direct-Instacom-Adapter-SW-1301/dp/B003ZS5X3S/ref=sr_1_fkmr0_1?keywords=sewell+direct+instacam&qid=1579805812&sr=8-1-fkmr0 https://www.amazon.com/Sewell-Direct-Instacom-Adapter-SW-1301/dp/B003ZS5X3S/ref=sr_1_fkmr0_1?keywords=sewell+direct+instacam&qid=1579805812&sr=8-1-fkmr0
the gauge is great with the digit read out for boost and AF, easy to read and is not small at all to see while driving,
Old Jan 25, 2020 | 09:53 AM
Warhawker's Avatar
https://www.amazon.com/Innovate-Moto...9805726&sr=8-1
https://www.amazon.com/Sewell-Direct...2&sr=8-1-fkmr0
Plus they are fun to look at with all their beep-boop lights.
Good luck, have fun
sterlinge
Jun 20, 2016 08:23 PM
GundamPilot
May 20, 2010 04:39 PM
prack7
Apr 2, 2009 01:59 PM
aiden1983
Dec 31, 2008 07:17 PM
Bar
Sep 4, 2008 05:10 PM
