XML for 50855085 EDM 2014 SST now available
Old Sep 29, 2021 | 01:18 PM
Slash200's Avatar
Hello,
I have created a xml definition for the 50855085 EDM 2014 SST Evo X.
As far as I know was there is no definition available for the public.
I have uploaded mine to Github. Feel free to contribute to it and please commit any changes to github so we can all benefit from it
BastianGschrey/50850002 (github.com)
best regards
Bastian
Old Oct 2, 2021 | 04:37 PM
richardjh's Avatar
Hi Bastian.
Good work.
I remember taking a quick look at a ROM ID with second set of four digits a repeat of the first. I found that the ROM ID's memory address was off by two bytes in the XML. Reckon you have the same issue here.
The example I saw was "50850002", but yours might differ. Without revising the "internalidaddress" in the XML header, you wouldn't know if it was 0002 or something else.
Take a look at memory address 5002e in the ROM to find out the actual ROM ID, then revise the XML like this:
Code:
<rom>
<romid>
<xmlid>50850002</xmlid>
<internalidaddress>5002e</internalidaddress>
<internalidhex>50850002</internalidhex>
<make>Mitsubishi</make>
<market>EDM</market>
<model>Lancer</model>
<submodel>Evolution X</submodel>
<transmission>SST</transmission>
<year>20XX</year>
<flashmethod>mitsucan</flashmethod>
<memmodel>M32186F8</memmodel>
<checksummodule>mitsucan</checksummodule>
</romid>
</rom>
Note that you may need something other than 0002. Use whatever you find in the specific ROM image you've worked through to provide a definition. I haven't touched it in git, as I don't know which ROM it's based on, exactly. The above tweak will clear that up, though.
Hope this helps.
Cheers,
Rich
Old Oct 11, 2021 | 11:37 AM
Slash200's Avatar
Hi Rich,
I have corrected it in the repository and added also the ROM to it
Maybe you can have a look at it if all needed tables are available that are needed for tuning.
If not you can tell me what is missing and I'll try to get the tables and calibrations with WinOLS
best regards
Bastian
-Dome-
Mitsubishi TC-SST Discussion
Apr 15, 2021 10:47 PM
EvoX22
May 7, 2018 06:42 PM
BoostingHard
Mar 12, 2015 11:54 PM
LVSBB6
Dec 8, 2009 11:49 AM
