help logging JDM ROM Evo X
Old Apr 6, 2022 | 03:16 PM
Llew's Avatar
I need some help with Getting accurate and usable LOAD values to properly tune my car.
Its a JDM 2008 Evolution X GSR SST Premium ROM ID 52370028
I will attach copy of my stock rom and sample data log.
The problem I am having is that the only datalog mode that makes sense is the EVO X CAN MUTIII when I use any other mode data such as speed rpm etc is not accurate. But when logging in eVO X CAN MUTIII I cannot get to log load that will easily help me tune the car. I would have to always guess the load cell im at based on RPM and Boost level so for instance I had to tune my timing map from load cell 140 upwards from 4500rpm upwards to get rid of knock had to decrement that whole block.
File Type: csv
File Type: hex
Old Apr 12, 2022 | 04:20 AM
crimson red's Avatar
Hi,
Did you enable mode23?
You can enable mode23 by changing values of the three tables(mode23 IFMode 0x05->0x23#1, mode23 IFMode 0x05->0x23#2, and mode23 DoMode 0x42->0x52).
After enabling mode23, 'Golden 2008 EDM v1 EVOX' or 'Golden 2008 EDM v2 EVOX' should shows accurate values.
scientist
Nov 23, 2014 12:54 PM
dEVOted_ix16
May 14, 2014 02:35 AM
mines5
Jun 18, 2013 09:49 AM
ms_logging
May 28, 2010 06:46 AM
philr8
Jan 4, 2010 11:12 AM
