Updated definitions for 56890013/56890014 (inside)
Old Aug 9, 2022 | 01:17 PM
Cole Crouter's Avatar
Exclamation Updated definitions for 56890013/56890014 (inside)
Got tired of all the old ROMs getting all the good features that I needed, so I mapped out most (I think) of the tables from 56890009. I don't know if these definitions are applicable to any other ROM IDs or not, I just did 56890014 cuz it's what I'm running right now (latest known 2011 USDM GSR ROM). Anyone more familiar than me, feel free to chime in.
Disclaimer: I'm pretty sure these are all correct, but use at your own risk blah blah blah.
Put this in C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\evo\ 56890013 2011 USDM Lancer Evolution X 5MT.xml
Code:
<table name="Low Pulse Width IPW Adder" address="556d8" scaling="IPW_Adder_div_2">
</table>
<table name="Asynchronous Injection - TPS Accel - Adder ECT based" address="55818" scaling="uint8">
<table name="ECT" address="618de"/>
</table>
<table name="Asynchronous Injection - TPS Accel - Adder RPM based" address="5a4aa" scaling="uint8">
<table name="RPM" address="5d5e2"/>
</table>
<table name="Asynchronous Injection - TPS Accel - Max TPS Threshold" address="55804" scaling="Percent255">
<table name="RPM" address="61622"/>
</table>
<table name="Asynchronous Injection - TPS Accel - Max IPW Limit" address="5310e" scaling="IPW 2byte"/>
<table name="Asynchronous Injection - TPS Accel - IPW per change in TPS" address="557f7" scaling="IPW">
</table>
</table>
<table name="Fuel Compensation MAT vs MAP - Stock3bar" address="61021" scaling="Percent_128_add_385_div_512">
<table name="MAP" address="63502"/>
<table name="MAT" address="634ee"/>
</table>
<table name="Fuel Compensation MAT vs MAP - Omni4bar" address="61021" scaling="Percent_128_add_385_div_512">
</table>
<table name="Load Accel/Decel IPW Enrichment/Enleanment Load Limit" address="55842" scaling="Loadify_x102">
<table name="Load" address="61606"/>
</table>
<table name="IAT Ignition Advance Compensation" address="56184" scaling="IgnitionCompensation">
<table name="IAT" address="61a58"/>
</table>
<table name="Cranking IPW" address="57c0a" scaling="CrankingIPW">
<table name="Coolant Temperature" address="6197a"/>
</table>
<table name="MPG Display" address="54124" scaling="MPG_Percent"/>
<table name="Reactive Solenoid Max WGDC vs CTS" address="5a500" scaling="WGDuty">
<table name="Coolant Temp" address="5d628"/>
</table>
<table name="Min Load for Fuel Pump High Voltage" address="59042" scaling="Load8">
<table name="Engine Speed" address="63ade"/>
</table>
<table name="Fuel Pump Low/Full Voltage Hysteresis" address="5348c" scaling="Load16"/>
<table name="OBTR (Over-Boost Timing Retard) Load" address="58d20" scaling="TimingOBTR">
<table name="Load Error" address="6301c"/>
</table>
<table name="Load" address="61622"/>
</table>
<table name="Load Accel IPW Enrichment - Countdown" address="530de" scaling="uint16"/>
<table name="Load Accel IPW Enrichment - Decay Rate" address="557a2" scaling="Percent256_1byte">
</table>
<table name="Load Accel IPW Enrichment - ignore Load changes smaller than this #1" address="557ae" scaling="Loadify_x50_1byte">
<table name="Load" address="616d0"/>
</table>
<table name="Load Accel IPW Enrichment - ignore Load changes smaller than this #2" address="557c8" scaling="Loadify_x50_1byte">
</table>
<table name="Load Accel IPW Enrichment - RPM multi" address="5a496" scaling="uint8">
</table>
<table name="Load Accel IPW Enrichment - ECT multi" address="5578a" scaling="uint8">
</table>
<table name="Load Decel IPW Enleanment - ignore Load changes smaller than this #1" address="55890" scaling="Loadify_x50_1byte">
</table>
<table name="Load Decel IPW Enleanment - ignore Load changes smaller than this #2" address="558aa" scaling="Loadify_x50_1byte">
</table>
<table name="Load Decel IPW Enleanment - RPM multi" address="55862" scaling="uint8">
</table>
<table name="Load Decel IPW Enleanment - ECT multi" address="55856" scaling="uint8">
</table>
<table name="Load Decel IPW Enleanment - Load multi" address="55876" scaling="uint8">
</table>
<table name="Hysteresis" address="5312e" scaling="Load16"/>
<table name="Min Temp" address="53130" scaling="Temp"/>
<table name="Start RPM" address="53132" scaling="RPMStatLimit"/>
<table name="AFR Enable" address="53134" scaling="AFR16"/>
<table name="Stop RPM" address="53136" scaling="RPMStatLimit"/>
<table name="AFR Clip" address="53138" scaling="AFR16"/>
<table name="LeanSpool AFR v FuelMap AFR" address="55900" scaling="AFR">
<table name="Base Fuel Map AFR" address="617aa"/>
</table>
EDIT: If you're out of the loop and/or missing 56890014, check here, it just inherits 56890013.
Last edited by Cole Crouter; Aug 9, 2022 at 01:20 PM. Reason: added where to get 56890014
ecuspec
Apr 8, 2018 12:11 PM
rschaffer
54
Sep 19, 2012 11:08 AM
2011OBGSR
Mar 15, 2012 10:30 AM
nightwalker
Nov 17, 2011 06:58 AM
WarmMilk
14
Feb 19, 2011 11:57 PM
