EVO X break in period?
Old Mar 21, 2008 | 03:51 PM
  #31
Evo_Jay's Avatar
Originally Posted by honda2EVO
sup guys, couple questions, so im new to the "EVO" world, went from 3 rsx's to a tsx and now the EVO X, im reading dfferent things about the 1st oil change, how do i know whos right? Also what is the PSI at while its being "broken in" and what does it go up to afterwards?
thanks
Dan
The boost is alway at the factory level, even during break in.
Old Mar 21, 2008 | 05:23 PM
  #32
mxpop's Avatar
Dont forget the cams guys.
Cosworth told me to hold the idle at startup to about 2000 for 20 mins with cooling fans etc. That was solely to break in the cams. Cams do not like to be broken in at low rpms.
They said go ahead and do the full tuning right after that. They also said to first prime the oil pump by disconecting the crank trigger until oil press is registered on the guage (which took about 10 secs of cranking).
After this break in and about 10 miles of dyno tuning, we went straight to the track and have had no problems.
Has anyone here ever had an issue with their motor that is truly traceable to poor break in?
BTW, motocross bikes (no factory warranty, period!) suggest 1 hour of medium use for a new motor and only 15 mins for a new piston/rings assy.
Old Mar 22, 2008 | 05:33 AM
  #33
JaxRRevoX's Avatar
went to to a local car meet last night , talkin to guy that recently got a evo x and had a evo VIII, he said that the evo x boosts 12lbs, then at 1000 miles it goes up to 14lbs, then at 1500 it goes to 16lbs and at 2000 to goes up to 18lbs.........................??
Old Mar 22, 2008 | 07:30 AM
  #34
CmakEVOX's Avatar
wont hurt to follow the manual. thats why its there.
Old Mar 22, 2008 | 12:52 PM
  #35
JaxRRevoX's Avatar
I know and i plan to
Old Mar 22, 2008 | 02:01 PM
  #36
PaulWalker's Avatar
Break it in like a ***** and it'll act like one. Don't be afraid to beat on it a little. These cars a really tough. i know some people on here are gonna scold me for saying that
Old Mar 24, 2008 | 08:19 AM
  #37
andrewzaragoza's Avatar
the important thing during the breakin period is not to baby the engine. do a lot of engine breaking.
read this site. its quite informative. http://www.mototuneusa.com/break_in_secrets.htm
Old Mar 26, 2008 | 11:29 AM
  #38
JaxRRevoX's Avatar
wow, interesting
Old Mar 26, 2008 | 02:56 PM
  #39
xPRimNT's Avatar
I've come across this before, but I really don't know what to think. The fact that it goes against many other opinions is mind boggling. While I don't trust that site in particular, I do trust people's experiences in the racing world.
So... Opinions on a brutal first 20 miles, then oil change?
Old Mar 26, 2008 | 03:32 PM
  #40
webshell's Avatar
I wonder if that has any truth... maybe explain the rich A/F
Old Mar 27, 2008 | 07:35 AM
  #41
EvoX-LI's Avatar
??? Can anyone confirm this? A boost gauge at low miles will confirm this.
Old Mar 27, 2008 | 10:10 AM
  #42
boozeup&riot's Avatar
so OP, what did you decide to do?
My vote would go for following the manual and not random strangers on the internet.
Old Mar 27, 2008 | 10:11 AM
  #43
baseline dynos from several companies which frequent these boards should confirm/deny this. I'm guessing its false.
Old Mar 27, 2008 | 12:02 PM
  #44
STi2EvoX's Avatar
Well, as far as my break in goes, I did a lot of half throttle accel and plenty of decel for the first 50 miles, keeping it at or below 4500 rpm. Then, I did some 3/4 throttle pulls to 5k rpm but not over for next 50 miles, and occasionally did some full throttle bursts to 5k rpm. When I hit 200 miles, I did fequent full throttle pulls to 5k rpm, and did lots of decel from that mark. I just made sure to vary the rpms as much as possible even on the highway, downshifting and then upshifting when not even necessary just to mix things up as much as possible. I did more and more full throttle pulls as time went on, but never over 5k rpms. After the break in of 600 miles, I started easing into 6k for about 50 miles, then 6.5k, and 7k a couple times over the next 50 miles. Then after about 700 miles I started doing some full throttle bursts to 7k progressively more and more. I did this until about 1000 miles, varying the rpms and load as much as possible, basically continuing that aspect of the break in period even past the necessary 600 mile mark. I have about 1100 miles on my car now, and it runs like a dream. I think that this is the best way to break in a motor, and that the mr moto's method is a bit too rough. I think that babying the car is not good either, so I would say that my method is a halfway point between the two. Extremes on either side of the fence are not good.
Old Mar 27, 2008 | 12:21 PM
  #45
JaxRRevoX's Avatar
im currently at 1100 miles, boost gauge is on, yesterday WOT 2nd gear i spiked at 24psi then it tappered down to 16ish
