EVOX meets Speed Element's Dyno Dynamics
Old Jan 30, 2008 | 05:19 PM
BOOSTEZ's Avatar
Originally Posted by EFIxMR
Ill try to throw up the boost comparison. Thing is that the boost on the EVO 9 was tapering hard too and had less peak psi.
Right, which is why it would be good to compare.
One thing for sure is that the EVOX runs rich as hell. Off the scale on my dyno which is something I never seen before on a car.
True, but the VIIIs/IXs ran rich as well (at least in the low 10 range). How much richer do you think the X is? 1 pt? 1.5pts?
Old Jan 30, 2008 | 05:50 PM
EFIxMR's Avatar
Updated with more comparisons
Old Jan 30, 2008 | 05:59 PM
EFIxMR's Avatar
One other interesting observation was that the owner told me the car dynoed better with the hood closed due to the location of the intake.
We tried it with the hood open and the hood closed, and to my surprise it was true!
The car picked up a few ponies and had better top end, hood closed.
Old Jan 30, 2008 | 06:07 PM
RazorLab's Avatar
9.5 AFR almost across the board on our mustang
Stock 9's usually don't go rich until way up in the RPM, mid to high 11's in the mid range. The 10 is pig rich the whole way through.
Old Jan 30, 2008 | 06:36 PM
Noize's Avatar
EvoM Administrator
I want to lean my car out post haste. I have no idea why they are so rich.
Old Jan 30, 2008 | 06:48 PM
evokel's Avatar
thats kinda good numbers i guess?
Old Jan 30, 2008 | 08:01 PM
EFIxMR's Avatar
Personally, I'm withholding judgement until I see a car tuned or otherwise modified locally.
But I think after seeing the boost and afr plots, that it shows alot of potential.
I mean if the car had good boost, and a solid 11.0 AFR the entire way through, and only made 21X whp, then I would be worried.
Sure, the EVO9 is making more power now, but how well would the EVO9 run if it had an AFR chart off the scale rich from full boost on?
Old Jan 30, 2008 | 08:12 PM
BOOSTEZ's Avatar
Probably would be a little lower in power, but then again, if you RAISE the boost up in the IX to 23psi peak and richened it out, I bet it would still make more power. We all know that the turbo on the X isn't going to hold up against the IX turbo so the only thing that will make the X gain more power than the IX would be if the engine itself is designed better than the 4G63.. which has yet to be proven.
Old Jan 30, 2008 | 08:49 PM
Mean TT's Avatar
I don't understand how the argument is made that the new engine (all 27 pounds lighter) is also cleaner - when you are dumping all of those hydrocarbons into the air. Something seems amiss with this strategy. Sure, NOx is reduced, but other pollutants are increased and fuel economy suffers. It seems rather odd to me that Mitsubishi will offer a 330 or 350 package that INCREASES FUEL ECONOMY AND POWER and then leaves both the performance minded and the *ahem* new fan base (read more environmentally active) behind the curve.
I don't profess to be any type of tuning expert, but it would seem to me that reducing peak engine RPM from the factory, as well as changing the timing would be the best ways to "limit" a motor's HP output.
IF MITSU BRINGS A DIESEL OUT AND PUTS IT IN ONE OF THEIR CARS and espouses the benefits if its design even though it weights 500 pounds, and then one breath later espouses the 27 pounds they saved and preprogrammed inefficient combustion with the 4B11, someone needs to hit them over the head with a mallet.
Old Jan 30, 2008 | 10:31 PM
PDXEvo's Avatar
From what we have seen so far with the addition of a TBE and intake leaning out the car quite a bit, I wonder if this was intentional. Most NA cars you can add intakes / exhausts without any issues, but I remember I installed an intake and TBE on my VIII and the AFR's got into the low 12's at redline. This is obviously very bad. I had to go back to a stock intake to alleviate this issue. I would say the most popular upgrades for the previous Evo's have been exhausts and intakes. However, we still have the unknown ECU element involved right now. I am still waiting to see what the learning process on this ECU is like, and how it makes its adjustments.
Thanks for sharing the dyno runs guys. Looks like we are seeing some very consistent runs across the board now.
Old Jan 30, 2008 | 10:46 PM
RazorLab's Avatar
We all know that the turbo on the X isn't going to hold up against the IX turbo...
We all know?
When did this happen?
Have facts to back this up?
Old Jan 30, 2008 | 11:02 PM
JohnBradley's Avatar
It seems that there is still a lot of time and things that need to be explored before claims about the X's turbo being insufficient are made. Timing and fueling have alot to do with boost, and the current inability to modify either of those doesnt point one way or another. Having a bunch of pre-release info that I was not allowed to divulge (apparently rightly so) till the car came out was that the turbo was supposed to be nearly a 20G. It doesnt seem that way, but I dont see why Mitsu would take a step backwards rather than at least maintaining or advancing (as evolution is defined).
I am with Bryan. Not enough data at this point to calculate the downside of the X turbo.
Old Jan 31, 2008 | 05:02 AM
3000ways's Avatar
Edited- Not needed question
Old Jan 31, 2008 | 02:05 PM
RazorLab's Avatar
Remember the 1G Eclipse (14B turbo) and the 2G Eclipse(T-25 turbo)??
They have done it before even though the 2G ended up with more power stock, it couldn't be carried nowhere near as far on the stock turbo as the 1G.. And that's a fact.
Well at least you are actually stating facts now. We all figured that out 13 years ago.
Right now, with the 10, nobody has those facts yet. Time will tell.
Please try and be scientific about it.
Speed Element
743
Apr 17, 2026 06:39 AM
razorlab
5165
Aug 11, 2024 07:56 PM
Ang Wen Yan
348
Jan 8, 2017 11:50 PM
rdtech
Aug 19, 2015 04:37 PM
Speed Element
Evo 'For Sale' Exterior Styling
Dec 19, 2006 04:32 PM
