EVO X - VIII motor comparison details
There's some balance of weight/strength, but the lighter you can make it while still being 'strong' enough, the better.
Part of that is all the G forces put on the recipricating parts. Those rods, pistons, etc, experience acceleration forces in the 100s if not 1000s G range. The heavier something is, the more force it takes to accelerate it, F=ma. So the heavier your rod, the more force it puts on the rod bearings, etc.
Weight has nothing to do with strength, its more material, design . as mentioned when you are moving the weight up and down this is what creates the force. heavy wt moving very fast means alot more load to break. light wt moving very fast less load. this is very basic but is a good starting point alot of small factors play into this as well. nice to see beefy internal to start with. looks like they did some R&D over the last 2 years.
Having said that, suppose you have 2 materials that are identical and one is heavier than the other. I would think that even though it takes more load to move the heavier weight up and down, that if there was a force opposing the weight (ie. detonation), that the lighter weight would break under less stress than the heavier.
What about that heavier rod when it reaches tdc and bdc, the bearings will be screaming at high revs along with the thinner neck portion of the rod. At some point the weight becomes an enemy. The newer rod design has been beefed up in all the right places and lightened stategically. Dr. Evo has made the best Evo engine ever...... until it is overhauled and redisigned for direct injection.
unobtainium to build your engine with.
AutoMotoSports
40
Jul 28, 2008 09:24 AM
AutoMotoSports
Automotosports - Illinois
Feb 14, 2008 05:29 PM
