Downpipe test = Zero gain
Old Jan 8, 2010 | 01:52 AM
  #106
flyboytb's Avatar
Originally Posted by evokenny
wow thats really nice to know [= no need for a aftermarket dp then , more money for other mods
downpipe / o2 housing combo does show gains... this is the setup most vendors offer.
Old Jan 8, 2010 | 06:43 AM
  #107
DaveGSR's Avatar
we're all looking for dyno proof of this...
Old Jan 8, 2010 | 08:07 AM
  #108
mlomker's Avatar
You guys resurrected an ancient thread where AMS showed no results with just the downpipe. I assume this was before they created and began selling their own o2/downpipe. It's the o2 part that gets you the gains.
http://www.amsperformance.com/cart/A...-Downpipe.html
There are all kinds of dyno graphs showing the gains from o2/downpipes. This is the brand that I bought:
Old Jan 8, 2010 | 09:17 AM
  #109
murlo26's Avatar
Originally Posted by UT_EvoX
That makes no sense since the O2 housing and downpipe are post-turbo restrictions. Making them higher-flowing would allow the same turbo on the same engine to produce more boost efficiently since the turbine wheel would be under less back-pressure on the exit side.
Same goes for replacing your exhaust with a high-flowing cat-back exhaust. It will decrease spool time and cause your boost to actually increase.
Eliminating intake restrictions and increasing internal engine efficiency would cause the effect you describe.
Trust me, I've been through countless iterations of exhaust systems on my other turbo car. Less post-turbo exhaust restriction = more boost. You're right about the required WGDC, however. But it's intake restriction that regulates boost pressure, not exhaust restriction.
Yea your right, I got my stuff crossed. Sooo this
Old Jan 8, 2010 | 02:42 PM
  #110
evoxdreamz's Avatar
Does the stock downpipe not have a cat on it? also jsut to be sure adding the 3 inch downpipe one like turbo xs without the o2 elbow adds no power?
Old Jan 9, 2010 | 01:40 PM
  #111
DaveGSR's Avatar
very cool, never saw this before
Old Jan 9, 2010 | 01:48 PM
  #112
flyboytb's Avatar
no and yes. the ams ets etc that are o2/dp combos are whats going to get you power.
Old Apr 3, 2014 | 04:37 PM
  #113
Robstunner's Avatar
Back from the dead, but....
Looking at the short DP that is required for Cobb OTS Stage 2, and then this thread, is there any reason why I cant just slap on the HFC from Cobb, and run the stock DP with a OTS stage 2 map? I can understand if cobb required the o2/downpipe as that looks and makes a difference, but the cobb dp only seems like a waist to just be able to run a stage 2 map.
Old Apr 3, 2014 | 05:38 PM
  #114
Gyroscope's Avatar
A lot of people are saying downpipe but they just mean the downpipe not the elbow. If you mean the elbow and the downpipe then say so. They are 2 different things even though some campanies make them the same thing...
Old Apr 3, 2014 | 05:59 PM
  #115
Robstunner's Avatar
I understand, I thought thats what I meant by o2/downpipe but either way, the questions there.
Old Apr 7, 2015 | 09:15 AM
  #116
JLEVOX's Avatar
Great info!!
Old Apr 12, 2015 | 12:29 PM
  #117
►EvolutionX◄'s Avatar
Originally Posted by JLEVOX
Great info!!
Great fourth post.
tscompusa
Aug 14, 2017 10:14 PM
tscompusa
Feb 17, 2017 11:45 AM
lostsoulsevo
Nov 19, 2015 04:14 AM
PERRIN_JOHN
24
Apr 23, 2009 11:01 AM
ballallday89
Oct 3, 2007 02:17 PM
