EVoX clutch
Old Feb 15, 2008 | 05:45 PM
DC5->EVO's Avatar
EVoX clutch
Those any one have reviews or pictures of the X clutch. what company produced it, what type is it?
Old Feb 17, 2008 | 10:30 PM
Sales@ACT's Avatar
The Evo X clutch is manufactured by Exedy and looks similar to the VIII & IX. The pressure plate is a pull type design and retains the same 240 mm diameter as the previous cars. The release bearing has been revised along with the clip that holds it in the diaphragm.
Old Feb 18, 2008 | 07:37 AM
wickedchimp's Avatar
Any idea what the holding power is on the stock clutch?
Old Mar 1, 2008 | 10:24 PM
kikin87's Avatar
appearantly its 350whp thats what a friend said but no clue if its true
Old Mar 2, 2008 | 01:19 AM
ONRAILS's Avatar
it depends on how you drive it.
some fried VIII stock clutches in 1-2k miles. Mine lasted 48k. And was still good I just built the block and upgraded clutches.
Old Mar 2, 2008 | 11:17 AM
Evo_Jay's Avatar
yep. Dont believe all the evo clutch horror stories.....
My VIII had 30-40 launches, 20K miles, stock clutch was fine.
My IX, 40K miles, 40+ launches, stock clutch fine.
Old Mar 3, 2008 | 01:31 PM
ACTman's Avatar
The clamp load of the pressure plate and the disc's friction material is unchanged so the torque capacity of the X clutch should be identical to the 8/9 clutch.
Old Mar 3, 2008 | 01:43 PM
tsitalon1's Avatar
ACT,
I notice a very long transition from disengagement to engagement, is that due to it's design or possibly the clutch delay valve?
This makes it impossible to quickly slip the clutch without burning the friction surface a bit.
James
Old Mar 3, 2008 | 01:48 PM
Thanks for the answer.
Old Mar 3, 2008 | 06:52 PM
ACTman's Avatar
I am sure it has a lot to do with it. If the car is abused, Mitsubishi would perfer to have you burn friction material at your expense (not covered under warranty) rather than break transmissions at their expense (warranty item). The best way to find out is to pull it out and compare how it drives. It is easy to try it and just as easy to put it back if necessary.
Originally Posted by tsitalon1
ACT,
James
Old Mar 3, 2008 | 08:38 PM
delkat's Avatar
I'm not sure the friction material is the same. Whenever I'm forced to slip the clutch on a steep hill or for whatever reason, a certain stench that I've not smelled before fills the cabin. It doesn't smell like any clutch material I've ever smelled before; kinda "rotten eggs" like.
Has anyone else noticed that?
Old Mar 3, 2008 | 09:39 PM
Evo_Jay's Avatar
Thats clutch. Clutch always smells like that.
Old Mar 4, 2008 | 01:37 AM
R0ME0's Avatar
I noticed that the engagement point is fairly high any way of adjusting this like you can on the Z and other cars etc?
Old Mar 4, 2008 | 06:44 AM
tsitalon1's Avatar
I have the same problem... I looked and didn't see the normal lock nut/threaded rod connected to the pedal assembly... I asked by Dealer and they said it's non-adjustable. I find that very hard to believe, I am in the process of locating a tech manual.
Old Mar 4, 2008 | 08:50 AM
R0ME0's Avatar
Keep us updated man!
MattyBoyMR
Aug 29, 2015 03:54 PM
Yaroslav
19
May 12, 2010 08:11 AM
EVO(boss)
Sep 5, 2009 12:27 AM
vladdyyy
Evo X How Tos / Installations
Oct 6, 2008 07:28 PM
redevo21
Dec 18, 2007 10:59 PM
