Problem
Old Mar 6, 2008 | 12:57 PM
jutilat's Avatar
Problem
I have a 2005 Lancer Evo 8. It was 40 degrees or so outside this morning and I went to start my car. It turns over a few times then a grinding sound happened. I had my brother try to start the car while I look under the hood and I see that the smaller thinner serpentine belt is turning and the belt thats going to my cam gears isn't moving. (sorry about the ignorant use of words) It kind of ticks back and fourth. I stopped him right away. What could it be?
Sorry wrong forum, should have been in evo 1-9. Reposted it there.
Old Mar 6, 2008 | 01:14 PM
gotevo?'s Avatar
It could be that you posted it in the WRONG forums.. heh.
GL!
Old Mar 6, 2008 | 10:15 PM
BrrrPshBrrr's Avatar
You've lost your timing belt. DO NOT TRY TO START IT AGAIN. You are just destroying internal metal parts.
Im sorry,but you need to do a timing belt,and if you were lucky- (I havent personally seen it,but Ive heard of it happening) you didnt hit the valves with the pistons.
Best of luck,but you need at least to change the belt,and most likely you need head work and clean up the valve hits on the pistons. Sorry.
Old Apr 25, 2008 | 10:58 PM
jutilat's Avatar
Yeah man, you got it. Valve smacked pison, needs head work. LAME.
Jsocpro20
Jan 30, 2012 11:48 AM
rob!
Jan 19, 2012 12:18 AM
gtpunk18
12
Aug 29, 2011 09:15 PM
iziegsx
Jul 29, 2011 11:59 AM
GgreyEVOIX
Mar 7, 2010 08:22 AM
