Should my turbo feel like this?
Old Apr 6, 2008 | 09:37 PM
  #46
TTP Engineering's Avatar
Its not the wastegate. Even if we had a wastegate for sale to the public, TTP would not say that the wastegate had a problem.
Increasing the preload on the stock wastegate much as Vishnu has, would accomplish greater results than an aftermarket wastegate.
Our .02c
Old Apr 8, 2008 | 03:24 PM
  #47
finallyaevowner's Avatar
the real ? is dose any ones x run right
as one more person to add to the list i to am having the same problem mine seems to be getting worse and im at a loss what to do about it as to weather it would be smarter to hold off let it run like crap and when i can afford to do the mods will have a better running car because of it or fix it with the reflash and hope all the mods still have the same gains with out hurting the engine if any one truley knows this in time or now i would love to know im a newbe love the sight my first evo and i love it
Old May 17, 2008 | 09:19 AM
  #48
forreal's Avatar
Originally Posted by tokeone
you can complain all you want and the reflash wont be out faster...
its pending government approval and is said to be due out late this month early may.
if you dont want to spend the $25 for a k&n cone filter cause youre afraid of voiding the warranty, pony up the $130 for the works drop in filter.
both will take care of the issue 95% (you still get a slight stutter up top in like 4th), just make sure to reset the ecu by unplugging the battery for a few minutes.
i almost have 7500 miles on my car with no issues.
Is resetting the ecu necessary to changing the drop in filter in this car?
Old May 17, 2008 | 09:58 AM
  #49
EvoJutsu's Avatar
Wasn't this resolved already?? There is a factory reflash for all Evo X under a certain VIN numbers.
Old May 17, 2008 | 10:23 AM
  #50
forreal's Avatar
Great!!! Could you bring your dealer to Jamaica so I can get it?
I'm not even interested in the reflash really, I'm eventually gonna tune it, once I finish bolting on the parts I want.
I'm just trying to confirm if you really have to reset the ecu (unplugg the battery) when putting in a HKS/Works drop in filter. Is this so???
Thanks.
Old May 17, 2008 | 12:50 PM
  #51
love9sick's Avatar
Thanks.
You don't have to. It is just a good idea.
Old May 17, 2008 | 01:02 PM
  #52
forreal's Avatar
Ok cool, thanks. Why is this a good idea?
Old May 17, 2008 | 02:26 PM
  #53
love9sick's Avatar
It allows the ECU to adjust itself a bit to the better air flow with the O2 sensors. Thought the drop in filter makes not the biggest difference or an intake in general. Just a good idea for the ECU.
Old May 17, 2008 | 03:22 PM
  #54
forreal's Avatar
Cool, much respect.
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
Turbo-Evo2346
Aug 28, 2012 01:08 PM
Dwalk08
Sep 3, 2010 10:55 PM
EVO MR FU
Jul 27, 2005 02:53 PM
2wenty2
Jul 8, 2005 12:58 AM
