MBC tapering
Old Apr 23, 2008 | 06:43 PM
mmachac's Avatar
MBC tapering
i need help with my boost controler. i have a turbonetics MBC and at 7k rpm it still tapers to 15 psi and i dont know if its the boost controler or just my boost guage not reading accurately. my boost guage is a autometer. and i also noticed that the needle bounces. lets say im holding 20 psi but the needle bounces between 19 and 21 really fast. is this normal? and i dont think its leaking i used teflon tape and everything is tight. and someone help me?
Old Apr 23, 2008 | 06:45 PM
mmachac's Avatar
also in 5th gear at 7k rpm the needle doesnt bounce its a constant 15 psi
Old Apr 23, 2008 | 07:13 PM
mksevo's Avatar
sounds about right. most people are putting the peak at 23 then it tapers to about 18. you are starting low and its dropping down to 15. move it up a hair to 22-23 and see where you final boost is then. most us are waiting until they can fix the boost with the ECU . only time will tell.
Old Apr 23, 2008 | 07:15 PM
dustin03's Avatar
have you take out the pill
Old Apr 23, 2008 | 07:16 PM
EvoHung's Avatar
Check your blow-off valve/diverter. Stock dv are notorious for robbing boost at high rpm.
Old Apr 23, 2008 | 07:19 PM
mmachac's Avatar
how do i take the pill out? and its set to 22 psi in 3rd gear and in 5th gear its at 24 psi and tapered to 15 psi.
Old Apr 23, 2008 | 07:21 PM
casper980's Avatar
Stock Turbo has Trouble holding boost in the upper RPM's
Old Apr 23, 2008 | 07:22 PM
casper980's Avatar
You take the pill out by cutting it out, or replacing the hose
Old Apr 23, 2008 | 07:23 PM
mmachac's Avatar
are you talking about between the waste gate and the boost source cus i have all new hoses between there?
Old Apr 23, 2008 | 07:27 PM
dustin03's Avatar
the pill is in the top line you can fill it in there like a bump
Old Apr 23, 2008 | 07:33 PM
mmachac's Avatar
i took that hose out. and i just looked at the hose i took out and it has a clamp over that pill right?
Old Apr 23, 2008 | 07:38 PM
dustin03's Avatar
the pill is about 1" inside that line feal the lines and like I said it you will feel the bump in the line. Take it out that will help with the boost tapper
Old Apr 23, 2008 | 07:45 PM
mmachac's Avatar
which line are you talking about? are you talking about this one
https://www.evolutionm.net/forums/sh...d.php?t=337560 its the 1st picture
Old Apr 23, 2008 | 08:14 PM
dustin03's Avatar
ok look at the first line cloest to you it has a bump in it that is the pill
Old Apr 23, 2008 | 08:18 PM
love9sick's Avatar
Is there a how to? for the pill anywhere? What does taking that out accomplish?
