CBRD intake...
Old Apr 29, 2008 | 10:17 AM
CBRD's Avatar
CBRD intake...
well, not really an "intake"
we popped a kn on the car, and made a nifty little bracket.
im strapping the car down now for some testing.
ill let you know what it does.
cb
Old Apr 29, 2008 | 10:50 AM
RazorLab's Avatar
Nice Chad,
Looking forward to seeing how that "new" style K&N works out. I was eyeing those for our kit as well.
Only thing I would be worried about in that position is the radiator fan washing the top of the filter with hot air.
Old Apr 29, 2008 | 10:57 AM
CBRD's Avatar
ok testing is done...
ill post results in a minute.
cb
Old Apr 29, 2008 | 11:08 AM
CBRD's Avatar
this is the X with the MBC (set to 20.5 psi)
versus stock solenoid at 22 psi
this was after we tightened the WG actuator, and you can see that the car definetly holds more boost up top, with less taper..
also notice the change in AFR's, about a full point at peak torque...
i wish i could log it and see what the timing is doing....
anyway, here is the chart....
pretty happy... 278/278... were the highest peak numbers, but i never post the absolute highest pull for testing.
cb
Old Apr 29, 2008 | 11:20 AM
RazorLab's Avatar
Chad those are gains from the filter or from filter + moving to MBC?
Old Apr 29, 2008 | 11:40 AM
no0odlez623's Avatar
cheep and easy power!
Old Apr 29, 2008 | 11:53 AM
CBRD's Avatar
Bryan,
those are filter/mbc/wg adjustment
im going to hook the stock solenoid back up and retest when i have time, but the X is on the scales right now.
cb
Old Apr 29, 2008 | 01:17 PM
J5isalive2's Avatar
so the real question is how much power did the filter give, and how much did the other adjustments make...
Old Apr 29, 2008 | 02:02 PM
CBRD's Avatar
im going to do more testing..
when i first got the car, i through a filter on it (from spt), and it picked up about 18whp.
cb
Old Apr 29, 2008 | 02:11 PM
FLOW1's Avatar
Nice, an intake.
Old Apr 29, 2008 | 11:26 PM
sndc5's Avatar
niceee
Old Apr 30, 2008 | 03:11 PM
STi2EvoX's Avatar
Chad, are these numbers made with the WG tightened one turn like you had it in the other thread, or has it been tightened even more since then?
Old Apr 30, 2008 | 03:48 PM
si_to_evo's Avatar
so a 40$ filter> $250 intake
CBRD
Jun 15, 2012 08:16 PM
CBRD
56
May 9, 2009 11:26 AM
CBRD
Oct 21, 2008 05:54 PM
CBRD
112
May 27, 2008 12:36 PM
CBRD
Oct 24, 2007 11:18 AM
