Steering Response Is SLOW On MY EVO X
Old Jun 12, 2008 | 04:18 PM
adnan626's Avatar
Hi everyone,
The steering on my evo is acting up. Before it started acting up, the steering was quick, responsive and the car felt planted on the road. NOW, it feels sluggish and slow (compared to before) and it just doesn't compare to how it used to be. Bumps upset the car *very* easily and it feels like the steering wheel has no control to the shaft.
I *tried* to install the audio controls on the steering wheel before it started acting up.
I disconnected the airbag and horn and stopped after taking out the airbag because it was dark already. Only then did I realize (glanced at the turned on interior lights ) that I forgot to disconnect the battery. Could this have caused all this??
I installed the audio controls next morning (after disconnecting the battery.) The lack of steering feel was still there so I went on plenty of drives to figure out the problem. I felt wobbling from the tires so checked the pressure and it was 55psi front and 60psi back . I'm glad they didn't blow up. Damn problem still exists!
I think this problem has nothing to do with opening up the steering wheel. I probably damaged some part of the shaft or something.
What do you think is causing this?? Thanks for reading and I appreciate your input.
Old Jun 12, 2008 | 04:22 PM
bluebyu36's Avatar
was it doing it before the install, sounds like something you did...
Old Jun 12, 2008 | 04:23 PM
No.9's Avatar
Originally Posted by adnan626
Hi everyone,
I would check to see if the tires are damaged from running 60 psi.
Old Jun 12, 2008 | 05:19 PM
adnan626's Avatar
No, it started doing this after the install. I've gone over everything I've done which might lead to this.
1. Disconnecting the airbag harness and honk and unscrewing the airbag while the battery is connected.
AND
2. The left-side of the front bumper did get damaged when I went over a slight parallel slope on the highway. The front bumper is about an 1" lower meaning a support or two are broken or damaged.
Ok, will do.
Old Jun 12, 2008 | 05:23 PM
Alexander's Avatar
did you take that measurement with the tires cold or hot?
Old Jun 12, 2008 | 05:32 PM
adnan626's Avatar
Hot.
Old Jun 12, 2008 | 05:44 PM
RKT SHP's Avatar
I have also done the blue-tooth mod on my car. what did you torque your steering wheel back too once you put that big nut back on...
AND
Ok, will do.
Old Jun 12, 2008 | 06:07 PM
beetle_orange's Avatar
^ +1 might be under torqued.
Old Jun 12, 2008 | 06:09 PM
adnan626's Avatar
I don't know how to measure the torque (?) while using the wrench. I tightened it making sure not to over-tighten.
How do you measure the torque when using the wrench?
Old Jun 12, 2008 | 08:58 PM
si_to_evo's Avatar
****THIS IS LIKE 5TH MEMBER COMPLAINING TIRES AT >50 PSI
WTF MITSU
Old Jun 12, 2008 | 09:10 PM
GrkBallaG's Avatar
WTF MITSU
No mean to threadjack but my tires were also at 50 psi for 1000 miles
Old Jun 13, 2008 | 12:36 AM
Cow town racer's Avatar
Use a torque wrench? Am I missing something here?
Old Jun 13, 2008 | 06:48 AM
CC16's Avatar
I thought the same thing about mine the other day, and then realized I had gotten used to it. Same reason it doesnt feel as fast anymore.
Old Jun 13, 2008 | 08:01 AM
BoricuaEVOX's Avatar
you can call to find out which one is it, ft lbs, or in lbs. and probably rent a torque wrench from Auto Zone. Good Luck
Old Jun 13, 2008 | 08:03 AM
fastevo03's Avatar
There is a steering wheel sensor on the steering wheel for SAWC, I am not sure if that is the cause. Even there is some problem with sensor it should have trigger the warning light
