Steering Response Is SLOW On MY EVO X
Old Jun 13, 2008 | 09:59 AM
evostang's Avatar
Originally Posted by adnan626
2. The left-side of the front bumper did get damaged when I went over a slight parallel slope on the highway. The front bumper is about an 1" lower meaning a support or two are broken or damaged.
So what I would do is go have the alignment checked. If you went over a "slight" slope with the tire, that was high enough to damage the bumper which is like five inches above the grouund, I'd be starting with the alignment check.
100% of every steering wheel I've ever seen has splined hub which fits onto a splined steering shaft. I seriously doubt the torque value of the nut holding the steering wheel on is making any difference. However, I have not removed the steering wheel in my car, so maybe Mitsu implemented a stupid design and I just don't know it.
Old Jun 13, 2008 | 10:05 AM
Alexander's Avatar
Originally Posted by GrkBallaG
No mean to threadjack but my tires were also at 50 psi for 1000 miles
This is your dealer to blame.
All cars are shipped with the tires over-inflated to avoid flatspots.
When your dealer does a "walk around prep" they are supposed to set the tires at the adequate pressure.
Old Jun 13, 2008 | 03:41 PM
RKT SHP's Avatar
well dude you got to get a torque wrench and check it out....if you look back in that how-to for blue tooth in the how to section..it tells you the torque(you really need to invest in a torque wrench if you plan on doing just about anything to your car).
EVERYONE.....remember he said that all this started AFTER he took off the steering wheel for the blue tooth upgrade not before
Old Jun 13, 2008 | 07:29 PM
adnan626's Avatar
Thanks for the ideas people.
I'm doing the following tomorrow to fix the problem.
-Tighten nut using torque wrench. Set to 33 ft-lbs (factory spec.)
-Get alignment.
I'll see what happens and will update with the fix.
Old Jun 13, 2008 | 07:39 PM
J5isalive2's Avatar
10 bucks says:
He reports back tomorrow that the problem is fixed.... even though he actually did nothing to rectify the situation.
Old Jun 13, 2008 | 07:43 PM
itsme4g63's Avatar
Originally Posted by J5isalive2
10 bucks says:
20 says quite opposite
Old Jun 13, 2008 | 08:02 PM
adnan626's Avatar
10 bucks says:
Thanks for your opinion.
So I had it over-torqued to 44 ft-lbs; I set it to 33 ft-lbs. I think part of it was paranoia that I messed it up when I opened the steering wheel. Part of it is that I'm already used to the power and handling like you mentioned CC16.
Old Jun 18, 2008 | 06:51 AM
bluebyu36's Avatar
TRADE IT IN FOR A SKYLINE
Old Jun 18, 2008 | 07:13 AM
Joe's Evo X's Avatar
Dang i need to check my tire pressure now that crazy.
Old Jun 18, 2008 | 07:17 PM
STi2EvoX's Avatar
So let me get this straight, there was really nothing wrong at all, that you were just being paranoid and thought that MAYBE you screwed up the install and that you couldn't remember if the steering felt sharper before or not? Good lord man.
RA11226
Evo X How Tos / Installations
120
Jun 24, 2022 03:19 AM
alex3dworld
84
Apr 21, 2016 08:36 PM
luckybull
Sep 19, 2013 12:19 PM
WolvieDC
Jul 13, 2010 02:32 PM
Jakeg97
28
Jun 13, 2010 06:16 AM
