ARC airbox on X
Old Jul 28, 2008 | 01:24 PM
  #31
TouringBubble's Avatar
Originally Posted by Hiboost
Just curious how you arrived at a single exhaust outperforming a dual on a 4b11 any day? Besides the obvious weight increase of the piping on a dual, if the first half of both exhausts are 3", and the last half is a Dual 2.5" or even Dual 3" versus a Single 3", wouldn't you think the backpressure of the last halves would be very similar on a dual 2.5" or LOWER on a Dual 3" exhaust? You can tune the exhausts for better NA performance but on a Turbocharged car usually just going lowest backpressure will result in the best performance under the curve when comparing them on a Dyno. Even for systems with 2 mufflers, wouldn't there be less backpressure when only half the airflow has to go out of each one? Just something to think about.
Backpressure isn't only determined by piping diameter ... flow can be restricted with bends as well. that's the basic argument for a single pipe vs duals.
The exhaust isn't outflowing even a single 3" pipe, so there is no added restriction with a single pipe as you are claiming, but the split in the dual system adds unneeded bends and restriction. This is the same principle behind the "JDM" style angled exit exhaust systems ... you eliminate a bend or two that would be needed to make the pipe exit straight out of the back and therefore lower backpressure.
Old Jul 28, 2008 | 04:58 PM
  #32
Hiboost's Avatar
True that makes sense. I guess that Y is a little tighter of a bend then I've seen on the Buschur or ETS dual catback, almost a T actually which I can see reducing some velocity.
fabcas311
Dec 30, 2015 01:24 PM
dimi108
Mar 18, 2014 02:45 PM
fabcas311
33
Sep 11, 2011 09:23 PM
chriz4
Mar 20, 2009 10:13 AM
chriz4
Mar 15, 2008 05:27 PM
