lot of carbon builtup on rear trunk from exhaust
Old Aug 24, 2008 | 05:16 PM
raz's Avatar
raz
Unhappy lot of carbon builtup on rear trunk from exhaust
hi guys i was just wondering if anyone is have problems with the carbon built up on the rear trunk from the exhust, this problem has existed since i bought the car , it happened with the stock exhaust and now happens with the bushur exhaust is this normal or is there something wrong witht he car, as the mitsubishi dealer said they have never heard of a problem
Old Aug 24, 2008 | 05:18 PM
Rguy's Avatar
Thats burned/unburned fuel cause the car is running so insanely rich.
Totally normal.
Old Aug 24, 2008 | 05:24 PM
DVDee's Avatar
My trunk turned brown from some night time spirited driving going from NY to PA. It literally looked like it was from another car that's how big the difference in color was. I have RRE's exhaust with 3 resonators, the samething happened on my stock on but this exhaust flows better is naturally it will spit out more. However this only occurs when I floor it. Normal driving is fine.
raz's Avatar
raz
so you are having the built up on the rear trunk, is there a fix as my car is white and gets dirty as soon as i wash it, very hard to make it loking nice
Old Aug 24, 2008 | 05:26 PM
EvilEvo9MR's Avatar
^correct and probably more now with the aftermarket exhaust verses stock
Old Aug 24, 2008 | 05:28 PM
DigitaLSD's Avatar
raz have you had a tune? not just the reflashes from Mitsu?
As someone above said it's cause it's running real rich and has a lot of unspent fuel. The first thing a tuner will do is lean it out, so this won't happen as bad as it is...
Old Aug 24, 2008 | 05:31 PM
raz's Avatar
raz
no i have not had it tuned, hard to find a good tuning place in canada if anyone has a link to a good tuner in canada toronto area please let me know, also mitsu has not reflashed anything on my car the local dealer has no clue about anything what are these reflashes are they from mitsubishi directly thankyou
Old Aug 24, 2008 | 05:34 PM
DigitaLSD's Avatar
Yes, I don't have the TSB offhand, someone else probably does, but Mitsu has released 2 factory reflashes (that I am aware of) that fix some things, from what I've read on here (Don't know for sure as I know **** about what is in the 2 reflashes) it also leans it out a little, but not anywhere near what a tuner is going to do
Old Aug 24, 2008 | 05:45 PM
raz's Avatar
raz
do i just contact my local dealer for the reflashes, or do i contact mitsubishi canada, i looked at some other forums and somebody recommended using ecuteck to tune the car has somebody used this application and how does it work thankyou
Old Aug 24, 2008 | 05:57 PM
DigitaLSD's Avatar
Question Number 1's answer is, call your Authorized Mitsu Dealership, they will have the tune info, especially if you dig up the TSB off the site here.
Question Number 2's answer, Ecuteck is a tune you would get from a tuner shop, you would need to go to a tuner to get it done. Ecuflash is the freeware version which you can do yourself, but I don't really know how to tune so Ecuteck is the way to go.
Whatever method a tuner uses (provided the tuner is skilled) he should be able to manipulate the proper tables (provided he has access via his tuning software) and be able to tune your car in a very good manner. It all comes down to their artistry at that point. Some people like Al, some people like Ivey, though I am sure they both do wonderful jobs, they just tune in their own respective styles.
Old Aug 25, 2008 | 08:44 PM
evostang's Avatar
To remove the stains you can use a clay bar available at most auto parts stores. Just follow the instructions, it's pretty simple.
Old Aug 26, 2008 | 06:20 PM
Maxmumboom's Avatar
My 97 c5 and the X both do that from running rich. I just spray some simplegreen on th back of the vette and hose it off then wash it. The only thing that sucks, is each time you use a degreaser it takes the wax off. But its cheaper and faster than clay bar.
1FastT2
Nov 23, 2009 07:41 PM
RaLLi
25
Jul 25, 2006 05:55 AM
RyanM
Jan 22, 2005 06:03 PM
3240
Jul 25, 2004 12:19 PM
