Sponsored by:
Sponsored by: CARiD
Trunk pops by itself!
Old Nov 21, 2009 | 05:19 AM
1FastT2's Avatar
Does anyone else have a problem with their trunk popping open by itself? Mine seems to have a mind of its own. When im in close vicinity of the rear of the car occasionally it will just open on its own with the keys in my pocket. I was thinking it had something to do with my cell phone maybe interfering with it however im not so sure. This happens almost daily and is starting to irritate me a little. Also the button on the trunk lid doesnt work so well. I know if I take it to the dealer I certainly wont be able to initate the problem. Any ideas?
Old Nov 21, 2009 | 08:01 AM
Hiboost's Avatar
Likely the button is jammed down partially and you get close to the activation zone it opens then trunk. Get that button fixed and you should be good.
Old Nov 21, 2009 | 09:18 AM
scottatyamaha's Avatar
If you have the SSS you should not keep your key and cell phone in the same pocket. It will most certainlty mess things up.
Old Nov 21, 2009 | 10:00 AM
SpeedI2acerX's Avatar
Paranormal activities..
Old Nov 21, 2009 | 10:51 AM
NYC-X's Avatar
Old Nov 23, 2009 | 08:44 AM
Webman's Avatar
I bet you're pushing the button in your pocket somehow. You can pop the trunk either by pressing twice, or holding the button.
On the trunk, just pushing the button will never open it. You have to hold it. It's only like half a second, but I've found that holding the button to pop it, is flawless every time.
Old Nov 23, 2009 | 09:11 AM
RaysEvoX's Avatar
I have the SSS and I keep my phone on at all times and never had this happen.
Old Nov 23, 2009 | 10:31 AM
Webman's Avatar
What cell carrier? I think it has to do with the phone's technology, as well as what's used on the phone. i.e. is it a GSM network, or CDMA. Or is it using bluetooth or some other technology that might interfere with the smartkey
Old Nov 23, 2009 | 12:44 PM
Evostare's Avatar
Same, I've never had an issue with my SSS key while having my phone in the same pocket..
i got an Iphone.. don't know if it'll screw things up with other phones but never had problems with mine.
Old Nov 23, 2009 | 01:43 PM
Bob Evolved's Avatar
I always have an issue with my SSS key while my blackberry is in my pocket. If they are in the same pocket it wont lock or unlock the doors
Old Nov 23, 2009 | 02:14 PM
therocket's Avatar
Originally Posted by hiboost
likely the button is jammed down partially and you get close to the activation zone it opens then trunk. Get that button fixed and you should be good.
+1
Old Nov 23, 2009 | 06:54 PM
Bluefire's Avatar
do cellphones and key work on the same frequency?
Old Nov 23, 2009 | 07:41 PM
Not to mention other electronic devices around your smart key with wear out your battery on the key twice as fast. Pick up and read your owners book.
Xenope
Jul 22, 2019 01:10 AM
onyx1121
May 21, 2009 08:02 PM
FiftyFive
Oct 26, 2007 08:25 AM
Adamk24
Oct 5, 2007 01:22 PM
nnorris7413
Aug 16, 2005 11:27 AM
