Found oil leak!
Old Sep 22, 2008 | 04:43 PM
tsitalon1's Avatar
The issue appears more serious than I thought.
I tightened the oil feed line banjo bolt to the block, cleaned the back side and t-chain side of the motor, and then drove the car hard for 5 minutes.
When I re-inspected, I can see a small trickle of oil making it's way down from directly behind the water pump. I cannot see it's origin.
I will take it in as planned.
As a side note, I also found the pass side front tire inner (motor side) completely worn. I have never hit anything and the car doesn' pull either direction. The 3 remainig tires look great.
I am quickly losing my patience and faith in this vehicle.
Old Sep 22, 2008 | 05:10 PM
Hiboost's Avatar
I noticed some drool on mine the other day as well... I'll snug it up and report back. Mechanics feel usually beats out torque specs on certain parts.
Old Sep 22, 2008 | 06:10 PM
NO_WAY's Avatar
^^ drool..... awesome...
Old Sep 23, 2008 | 06:52 AM
tsitalon1's Avatar
After looking a little more closely, I beleve it to be leaking at the timing cover right at the water pump.
It's a small leak, not dangerous at all but very annoying for a 39k car!
Old Sep 23, 2008 | 06:57 AM
Hiboost's Avatar
Yeah not really sure what to make of it honestly.
Old Sep 23, 2008 | 07:09 AM
tsitalon1's Avatar
Have you look at your's yet?
It simple, just remove the oil filter cover panel, and look up directly above the oil pan drain plug. You should see oil on the back side and t-chain side of the motor.
I recommend everyone check asap.
Old Sep 23, 2008 | 07:15 AM
Nsomniac's Avatar
EvoM Administrator
I will be taking mine in tomorrow as I too have apparently contracted this disease. It's just a few drips, but it certainly isn't the oil pan gasket. I will let you know my findings as well when I have more time to observe (daylight).
Old Sep 23, 2008 | 01:27 PM
shyong's Avatar
at the dealership as I type this. service guy doing the oil change found the same oil leak. he can't pinpoint where it's exactly coming from. he's putting in some dye and i'll be coming back in about a couple weeks. i hope this **** isn't serious. i blew it off when i personally did the first oil change myself. i thought the drain bolt wasn't on tight. this worries me now.
Old Sep 23, 2008 | 02:01 PM
tsitalon1's Avatar
I'm betting t-cover...
A couple weeks...drive that $hit around the block. I was able to reproduce the leak in 5 minutes of hard driving.
BTW....have them report it to Mitsu techline. If enough reports come in, they'll create a TSB.
Old Sep 23, 2008 | 03:58 PM
tsitalon1's Avatar
Created a seperate thread for tire issue.
Can be found here --> https://www.evolutionm.net/forums/sh...65#post6149365
Old Sep 23, 2008 | 05:03 PM
Joe's Evo X's Avatar
wow this is crazy. I bet a lot more people have this just havnt taken the plastic off to see it yet. Very scary. Everyone need to check there oil level.
Old Sep 23, 2008 | 05:51 PM
shyong's Avatar
I noticed on my first oil change but didn't think anything of it. I was thinking maybe someone at the factory forgot to tighten the drain bolt...or missed the spot filling the motor.
Bottom of the chassis and plastic was drenched with oil. I looked underneath the car after I got home today...it looks the same. That's bad considering I cleaned up the chassis and plastic plate the last time I did the oil change. We're not talking a couple or even a few drops of oil here. It looks like at least half a cup of oil. That's a lot. I'm hoping the fix to this isn't going to be extensive.
I would recommend everyone to check the bottom of their Evo. I'm going to take in the car back in on Thursday. Service advisor asked me to put at least 200 hundred miles before bringing it back in. I'm guess the dye helps pinpoint exactly where it's leaking.
Old Sep 23, 2008 | 05:56 PM
tsitalon1's Avatar
This is much more severe than mine. Mine is a small trickle that coats oil on the block and pan. My oil level was fine as well. We may or may not have the same issue. My guess is still the t-chain cover.
Old Sep 23, 2008 | 07:52 PM
shyong's Avatar
Don't get me wrong. My oil pan is covered with oil too. i don't have a noticeable drip per se on the garage floor...but it's leaking somewhere. I took it for a drive tonight trying to add miles so I can have enough for thursday. Hopefully they figure out the location of the leak. They're wanting to keep my car for a day or two.
Old Sep 23, 2008 | 11:22 PM
Ya i am hoping a TBS comes out for this cuz i am scared that they will charge me to fix this givin my mods.
