clutch master cylinder
The first one, a larger pump was used and made the pedal a little stiffer than expected (althoug it still works flawlessly), but if an smaller diameter pump is used the pedal fell would be even better.
Plus:
Plus:
- The pedal height is adjustable
- The pump is 100% rebuildable (if it ever fails, ha ha ha)
- Muchhhhh stronger than any other option
Plus:
Plus:
sorry for spilling the beans on that mod
but hey we wants permanent... ask and thou shall receive eh?
The first one, a larger pump was used and made the pedal a little stiffer than expected (althoug it still works flawlessly), but if an smaller diameter pump is used the pedal feel would be even better.
Plus:
Plus:
I will have my tranny/clutch and CMC out this weekend. I would love to do this.
Does it bolt right up without drilling the base plate and pedal?
According to our experience the pump does not have to be extremely large to work.
His phone number is 787-458-6866
The car and idea was mine, but the installation process belongs to a friend of mine called Abdiel from TransmisionesPR.com, but I can tell you this much, YES the base has to be drilled and the pedal has to be lightly modified to accept the helm joint.
Carrito, what bore master cylinder did you use, and which bore would you recommend instead?
LOL, you might as well get the dealer out of your mind when it comes to installing aftermarket parts on your car, especially if anything needs to be modded to accept the part. I'm kinda amazed some dealers agreed to install aftermarket clutches on customers X's. That normally is a no no.
