[HELP] my evo x under power problem.
Old Oct 16, 2008 | 07:40 PM
hoongss's Avatar
Hey
I dont know what is the reason, but my car (evo x) suddenly seems like lost its power.
I can only go around 40mph in 3rd gear with around 5k rpm.
1st gear around 15mph at 4.5k rpm.
Anyone know what is the problem? I will bring my car to the dealership tomorrow, but I want to make sure the dealership never give me any dumb excuse to void my warranty. I never do any mod to my car, it is completely stock.
From what i heard, it is either the clutch wear out or the clutch is too hot.
Please help!!!!!!!
Thanks
Old Oct 16, 2008 | 07:41 PM
xtremeboost's Avatar
Do you have the check engine light on ? if so have you tried to re-set the ECU ?
Old Oct 16, 2008 | 07:47 PM
hoongss's Avatar
check engine light is not on.
everything is completely from the inside and the lights on the dash.
just then when i drive, it is like losing hp. slower then a geo metro =.=
Old Oct 16, 2008 | 07:51 PM
hose popped off !!
Old Oct 16, 2008 | 07:55 PM
hoongss's Avatar
which hose? i check all the hose, looks like it is completely seal.
do you think maybe it is the spark plug?
Old Oct 16, 2008 | 07:56 PM
DynoFlash's Avatar
I agree with vendor above - prob a boost hose poped loose
Check all the vac hoses and fmic hoses
Al
Old Oct 16, 2008 | 08:33 PM
hoongss's Avatar
ok
I will check that tomorrow in the morning.
Do you think there is possible of clutch wear?
Old Oct 16, 2008 | 08:35 PM
ok
From you you posted above it seems like a hose , check very close . Other members have had the very same issue its its turned out to be just a hose .
Old Oct 16, 2008 | 08:42 PM
hoongss's Avatar
which hose especially should i check with?
i am kinda noob here. thank you.
Old Oct 16, 2008 | 10:10 PM
dierr's Avatar
what mods do u have? i had a boost leak and it was from my lower ic pipe. put that back on. straightened everything out. and i'm good!
Old Oct 16, 2008 | 10:24 PM
hoongss's Avatar
no mods.
my car is 100% stock
Old Oct 17, 2008 | 08:20 AM
MOREPSiTEHBETT4's Avatar
check all your intercooler hoses, do you have a boost gauge..if so what's your vaccum? boost you are achieving?
Old Oct 17, 2008 | 08:22 AM
hoongss's Avatar
i already send my car to the dealership.
and they say that my clutch wore out.
it cost around $1300 to fix everything
damn! why evo x wear out so fast!
Is after market clutch cheaper and better?
Old Oct 17, 2008 | 08:41 AM
ibarkovic's Avatar
dont go for oem clutch , get an act street clutch and get an known evo/dsm shot to install it for you , it should come out to like 1100-1200 with clutch and it will be so much durable.
Old Oct 17, 2008 | 09:22 AM
Massappeal's Avatar
Yes stock evo clutch sucks! if you get another stock one plan on getting a new clutch again soon. Go aftermarket if you are replacing
