Ultimate Racing downpipe with o2 housing
Old Oct 19, 2008 | 01:50 PM
Evo VIII 4G63's Avatar
Anybody put on a ultimate racing downpipe with there integrated o2 housing. Here is what i found out about the stock downpipe. Everybody on here is complaining about the ticking noise coming from the engine bay while i was installing my forge wga i removed the heatshield to find a big black spot on it from an exhaust leak at where the downpipe meets the stock 02 housing so people with the tick should check that out on there cars. So my question is will the stock cat mate up with the ur downpipe and o2 housing gonna replace the stock downpipe cause of the exhaust leak.
Old Oct 19, 2008 | 02:06 PM
Silentbob812's Avatar
I asked them this question and Darryl told me that it is made to replace stock, so it should mate up.
Old Oct 19, 2008 | 03:25 PM
Guru's Avatar
I got mine ceramic coated to keep the heat out of the engine bay as much as possible. I have a test pipe but looking at it it should mate up fine to the stock cat as the stock cat is a simple 2 bolt flange. Why would you keep the stock cat?
Old Oct 19, 2008 | 05:55 PM
do new gaskets come with the downpipe im ordering mine from lancershop
Old Oct 20, 2008 | 06:40 AM
Ultimate Racing's Avatar
Thumbs up
Our Evo X O2 Housing Downpipe is designed as a stock replacement for both the OEM O2 Housing and OEM Downpipe.
That being said, it will fit the OEM catalytic converter, as well as any other direct fitment cat replacement pipe like our Evo X Test Pipe, and Evo X High-Flow Cats.
Darryl
www.ultimate-racing.com
Old Oct 20, 2008 | 06:42 AM
Cool
Just to add to the discussion, the large OEM heatshield can still be fitted with our O2 Housing Downpipe installed
Darryl
Old Oct 20, 2008 | 07:10 AM
switchblade906's Avatar
i wish that was out when i bought my downpipe, i still need to order the resonated test pipe from you guys as well
Old Oct 20, 2008 | 07:48 PM
ikuto's Avatar
Darryl
How does your O2 Housing Downpipe fit with the OEM Heat Shield? When I took the Heat Shield off it had couple of bolts to secure the Heat Shield but I don't see any spots on your Downpipe to bolt down and secure the OEM Heat Shield? I'm not sure but i think it bolts down to the O2 Housing/Downpipe .
Old Oct 21, 2008 | 06:26 AM
Guru's Avatar
The large heat shield on top is the one I'm sure he is talking about which should fit fine. It has bolts on the manifold to hold it on I believe.
Old Oct 21, 2008 | 07:34 AM
ikuto's Avatar
Yes, thats the one. Thanks for clarifying that. When I had to remove and install it back to get to my wastegate I ended up with clicking noises because the Heat Shield was not bolted down tight enough. It doesn't just bolt to the manifold, but to the downpipe as well so that it wraps around it securely. I'm just concerned that if there aren't spots to bolt down the Heat Shield like the OE downpipe, then it might make some unwanted noise from the Heat Shield.
cerealkeller
Sep 7, 2016 04:50 AM
nzmusclez
Aug 23, 2016 04:33 AM
P!N-EVOVIII
Mar 14, 2010 10:50 AM
BerserkerX
13
Feb 25, 2009 03:03 PM
03redtype-s
Mar 2, 2006 09:10 AM
