AEM Water/Meth Injection FailSafe.
i know that aem has a failsafe output. my question is what do you connect the 12v output to? does the stock ecu has a input so that we can program the ecu to retard timeing if there is anything wrong with the AEM system? do we need a coonect the failsafe to something to vent the boost of the wastegate.
kl
kl
this is what I connected mine to
http://www.labontemotorsports.com/st...ow/BBK-20.html
4myx,
the part from labonte (bbk-20) is all we need to set up the aem system?
does the labonte take the 12v output that the aem system put out?
do we need anymore fail safe device?
which size tank did you go for? would you go for a 5 gallons tank? how long does the 1 gallon tank last you? where did you mount your tank?
thanks
kl
thanks
kl
4myx,
thanks
kl
thanks
kl
thanks, the install is very clean. where did you get the black plexi board in the back?
i just ordered my aem kit and the bkk-20.
going to get the clutch and the turbo(very likely the blouch dom 3) and will get everything to install when all the needed parts are in.
thanks again
kl
thanks again
kl
4myx,
what kind of mixture do you use?
do you mix it yourself(how do you do it?0, use premix (where do you buy it website?) or windshield fluid (which brand?)?
thanks again
kl
thanks again
kl
I was just wondering where you guys placed the nozzle and how you mounted it. I have heard that the best place is on the LICP before the throttle body. Also, is any welding involved to mount the nozzle. Thanks.
thanks again
kl
thanks again
kl
Now as of the meth/mix I bought boost juice that comes in a box of 4-gallons from a gentelman who is on the forum, he sales them on e-bay. Snow performance makes the stuff, its 49% meth 51% water. You can also just go to a race shop and buy meth and mix it yourself, its alot cheaper that away, thats probably what ill be doing when Ive used up all the boost juice. Just make sure if you mix it to use purifed water.
